Custom Widget Error
3062
08-14-2014 05:47 AM
PeterCarroll
I'm new to this ArcGIS game and I'm trying to put together a custom widget following the tutorials on esri's site. The problem is that when I go to create a new instance of it, the browser console throws up the error message 'Object doesn't support this action'. Has anyone come across this before and know where to look for the cause?
Peter.
AnthonyGiles
Honored Contributor
Peter,
I think you need to put tags on your post to which language you are using, and post your question into the relevant space that way you are more likely to get a response:
ArcGIS API for JavaScript
ArcGIS API for Flex
ArcGIS API for Silverlight
PeterCarroll
Thanks, Anthony, I’ll give that a go.
Regards
Peter
P.S. Problem solved; it was an issue with the path to the template file.
