Collector app - place point manually?
3181
08-01-2014 08:16 AM
LisaSmith
New Contributor III
Is there a way to collect a point without the app using my 'current' location.  Even after adjusting accuracy to 5m (the best it will let you),  I am not able to place the point manually at the exact spot I know a sample has just been collected.  Is there a way to override this and place the point myself?
GaryMorris1
You can tap on the map to mark the location of the point instead of using your GPS position.  If you long press on the map, you get a magnifier that allows you to more precisely choose the location.   (You can also start with the "Collect here" option, which I described in a blog post yesterday.)
This is what placing a point with the magnifier looks like (on iPhone):
GaryMorris1
LisaSmith
New Contributor III
Thanks Gary!
