Change Virtual Output Directory URL to HTTPS instead of HTTP
1099
07-15-2014 07:38 AM
RaphaelDürst
Our ArcGIS 10.1 server is installed in a DMZ behind a web-proxy that terminates HTTPS and forwards HTTP to the ArcGIS server. Thus the connection between the web-proxy and the ArcGIS server is always HTTP even though the browser sees the ESRI map with HTTPS. This setup works fine until we use the virtual output directory in combination with the DynamicMapServiceLayer. The response of the export script (https://www.comfone.com/arcgis/rest/services/country_outline/MapServer/export?) points to a HTTP address instead of a HTTPS. Is there a configuration in ArcGIS 10.1 where I can define the virtual output directory path to be set to HTTPS?
It seems that there was exactly this feature in a older version (section 3):
Thanks for your support.
