Using a standard button to trigger a locator / script
3447
7
07-09-2014 03:38 PM
MatthewBaker2
All,
I'm trying to figure out how to use a standard button component to trigger a locator rather than a DOJO component
I was given a hint to try
on(dom.byId("buttonID"), "click", locate);
...but I can't get that to work.
UPDATE: I've attached some code with the suggestion by jskinner-esristaff‌ from comments below - solution is working great. Thank you!!!
Thanks!
JakeSkinner
Esri Esteemed Contributor
Hi Matthew,
Your code is correct, you will just need to reference the "dojo/on" module.  Ex:
require([
      "esri/map", "esri/tasks/locator", "esri/graphic",
      "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
      "esri/symbols/Font", "esri/symbols/TextSymbol",
      "dojo/_base/array", "esri/Color",
      "dojo/number", "dojo/parser", "dojo/dom", "dijit/registry", "dojo/on",
      "dijit/form/Button", "dijit/form/Textarea",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
function (
  Map, Locator, Graphic,
  InfoTemplate, SimpleMarkerSymbol,
  Font, TextSymbol,
  arrayUtils, Color,
  number, parser, dom, registry, on)
JakeSkinner
Hi Matthew,
require([
function (
  Font, TextSymbol,
  arrayUtils, Color,
MatthewBaker2
Jake Skinner‌, I've added the code I'm working with - also adding what you've suggested, but still no luck.
JakeSkinner
Looks like there were a couple of errors.
1.  In you 'outFields' parameter, the field needs to have quotes, i.e. "grades"
2.  I would recommend using map.centerAndZoom to zoom to the results
One thing I'm not sure is how to call the zoomTo function from the table.  You may want to start a new thread for this.
Here is the code I was able to get to work:
<!DOCTYPE html>
<html>
  <head>
    <title>Geocode Details</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
    <style>
      html, body {
        height: 100%;
        margin: 0;
        padding: 0;
        width: 100%;
        color: #353129;
      #map {
        margin: 0;
        padding: 0;
      #footerPane {
        border: none;
        height: 300px;
    </style>
    <script src="http://js.arcgis.com/3.9/"></script>
    <script>
      var locator, map;
      require([
        "esri/map", "esri/tasks/locator", "esri/SpatialReference", "esri/graphic",
        "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/Font",
        "esri/symbols/TextSymbol", "esri/geometry/Point", "esri/geometry/Extent",
        "esri/geometry/webMercatorUtils", "dojo/_base/array", "esri/Color", "dojo/number",
        "dojo/parser", "dojo/dom", "dojo/json", "dijit/registry", "dojo/on",
        "dijit/form/Button", "dijit/form/Textarea", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      function(
        Map, Locator, SpatialReference, Graphic,
        SimpleLineSymbol, SimpleMarkerSymbol, Font,
        TextSymbol, Point, Extent,
        webMercatorUtils, arrayUtils, Color, number,
        parser, dom, JSON, registry, on
        parser.parse();
        map = new Map("map", {
          basemap : "streets",
          center : [-93.5, 41.431],
          zoom : 5
        locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
        on(dom.byId("noDojo"), "click", locate);
        //Draw and zoom to the result when the geocoding is complete
        locator.on("address-to-locations-complete", function(evt) {
          map.graphics.clear();
          arrayUtils.forEach(evt.addresses, function(geocodeResult, index) {
            //create a random color for the text and marker symbol
            var r = Math.floor(Math.random() * 250);
            var g = Math.floor(Math.random() * 100);
            var b = Math.floor(Math.random() * 100);
            var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([r, g, b, 0.5]), 10), new Color([r, g, b, 0.9]));
            var pointMeters = webMercatorUtils.geographicToWebMercator(geocodeResult.location);
            var locationGraphic = new Graphic(pointMeters, symbol);
            var font = new Font().setSize("12pt").setWeight(Font.WEIGHT_BOLD);
            var textSymbol = new TextSymbol((index + 1) + ".) " + geocodeResult.address, font, new Color([r, g, b, 0.8])).setOffset(5, 15);
            //add the location graphic and text with the address to the map
            map.graphics.add(locationGraphic);
            map.graphics.add(new Graphic(pointMeters, textSymbol));
          var ptAttr = evt.addresses[0].location;
          map.centerAndZoom(ptAttr, 19);
          showResults(evt.addresses);
        function showResults(results) {
          var rdiv = dom.byId("resultsdiv");
          rdiv.innerHTML = "<p><b>" + results.length + " Matching Results:</b></p>";
          var content = [];
          //start table
          content.push("<table border='0'><tr>");
          arrayUtils.forEach(results, function(result, index) {
            var x = result.location.x.toFixed(5);
            var y = result.location.y.toFixed(5);
            content.push("<tr><td>");
            content.push("<input type='button' id='zoomButton' value='Z' onclick='zoomTo(" + y + "," + x + ")'/>");
            content.push("</td><td>");
            content.push("<legend><b>" + (index + 1) + ". " + "<a target='window' href='http://test.com/" + result.attributes.LangCode + "'>" + result.address + "</a></b></legend>");
            content.push("</td></tr>");
          content.push("</tr></table>");
          rdiv.innerHTML += content.join("");
        //Perform the geocode. This function runs when the "Locate" button is pushed.
        function locate() {
          var address = {
            SingleLine : dom.byId("address").value
          var options = {
            address : address,
            outFields : ["grade"]
          //optionally return the out fields if you need to calculate the extent of the geocoded point
          locator.addressToLocations(options);
        function zoomTo(lat, lon) {
          var point = new Point(lon, lat, {
            wkid : "4326"
          /*var wmpoint = webMercatorUtils.geographicToWebMercator(point);
          map.centerAt(wmpoint);*/
        map.centerAndZoom(point, 19)
        function showThing(thing) {
          alert(thing);
        function clearDiv() {
          document.getElementById('resultsdiv').innerHTML = "";
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
    data-dojo-props="gutters:false, design:'sidebar'"
    style="width:50%;height:100%;">
      <div>
        Address :
        <input type="text" id="address" size="60" value="380 New York St, Redlands, CA, 92373"/>
        <!-- <button id="locate" data-dojo-type="dijit/form/Button">
          Locate
        </button> -->
        <button id="noDojo">
          Locate me without Dojo!
        </button>
      </div>
      <div id="map"></div>
      <div id="footerPane">
        <div id="resultsdiv"></div>
        <button onclick="clearDiv()">
          Clear Div
        </button>
      </div>
    </div>
  </body>
</html>
TimWitt2
Matt,
there is an issue in your locate function. The following error pops-up:
Uncaught ReferenceError: grade is not defined
when I remove your
outfield: [grade]
it seems to work.
MatthewBaker2
I'm sorry, I got my samples mixed up and added that by mistake...
jskinner-esristaff‌ your solution worked great. Thank you!
and thanks timw1984dev‌ for pointing this out!
JohnGravois
hey matthew,
please consider marking Jake's reply as the 'answer' to this thread when you have a minute.
MatthewBaker2
... I was busy going through all my GeoNet notifications...!!!
