Multiple attributes in one Popout window
2794
6
01-09-2014 07:58 AM
Chang-HengYang
HI all,
The attached file shows the popout window (identify)in Flex API. I wonder if someone knows how to make a similar popout window in Javascript API. The popout window displays the information according to the layers you want. For example, I can click the "Earthquakes > 1M", and information about this specific layer is displayed.
Hank
KenBuja
MVP Esteemed Contributor
You can set the content of an infoWindow to be just about anything you want. I don't know of any specific popup that would have the capability of what you're looking for, but you can be quite creative. It's just a matter of coding it.
You've probably seen the samples of Popup and InfoWindows that show several different ways of formatting it. Here's an example where I use a dGrid to show the results of an IdentifyTask for multiple layers in a dynamic layer.
KenBuja
Chang-HengYang
Hi Ken,
Thank you for the reply. Your popout window format is what I want. I will study your script.
Many thanks,
Hank
KenBuja
I'm glad to help. Please remember to click the check mark if this answered your question. This helps others searching for a similar answer.
JonathanUihlein
+1 to Ken for both a solid answer and using dgrid in a popup.
JerryHughes
Ken,
I would also be interested in view the script to display Multiple attributes in one Popout window.  Where can I view the script?
jerry
KenBuja
If you right click on the page, you can see the code using View Source (IE) or View Page Source (Chrome and Firefox).
