Geocoder widget placeholder text not showing up in Internet Explorer
2271
01-14-2014 09:58 AM
JeremyManning1
I'm building a map application with the latest version of the JS API (3.8) and am using the Geocoder to consume my own geocoding service (see code below). I've assigned the placeholder text attribute a value of "Find address" and it shows up just fine in the search box in Chrome, Firefox, iOS, Android, etc. but does not show up at all with Internet Explorer. Is this a known bug and if so is there any workaround?
var myGeocoders = [{
url: "//ags.crgov.com/ArcGIS/rest/services/AddressLocator/GeocodeServer",
placeholder: "Find address"}];
var geocoder = new Geocoder({
map: map,
arcgisGeocoder: false,
minCharacters: 6,
autoComplete: true,
showResults: true,
autoNavigate: false,
geocoders: myGeocoders},"search");
ReneRubalcava
Esri Frequent Contributor
This isn't specific to the JS API, the placeholder attribute is only suppored in IE10+.
http://caniuse.com/input-placeholder
Here are a couple of links to (no dependency) placeholder polyfills you can try out.
Note, I haven't tested these.
ReneRubalcava
