Geocoder Results grid - how to position
1939
05-30-2013 05:59 AM
LuciHawkins
I incorporated the geocoder widget and the results grid ends up being in a weird place.  I have the <div>search<div> in a contentpane in an accordioncontainer and the results end up at the bottom of the contentpane instead of right below the search div.  Any ideas on how I can customize the css to make it appear in the correct place.
Luci[ATTACH=CONFIG]24810[/ATTACH]
MattDriscoll
It seems like putting the geocoder widget inside of another container with a CSS property/value of position:relative; would do the trick. Or you could adjust the CSS of where the results div is positioning to not use absolute positioning.
MattDriscoll
LuciHawkins
Hey Matt,
You pointed me in the right direction.  What I ended up doing is adding this to my css file:
.simpleGeocoder .esriGeocoderResults {
position:relative;
Now the results show up in the right place 🙂
Thanks!
Luci
MattDriscoll
Hey Matt,
position:relative;
Thanks!
Luci
Awesome 🙂
Glad that worked!
