How to get map description using vb.net
1182
02-27-2013 09:59 AM
JamesFinlay
Good day,
I am currently trying to figure out how to access a MapDocument's description as set in the File > Map Document Properties. I am trying to access it through a VB.NET add-in. The image below shows the description field I am referring to:
[ATTACH=CONFIG]22221[/ATTACH]
I found it easy enough to access the basic info here, such as the Title, but I cannot find a way to get the description programmatically. Here is the code I have to get the Map Document Title:
 ' Open Map Document Info Dim theMapDoc As IMapDocument = New MapDocument theMapDoc.Open("TheFileName.mxd") Dim theDocInfo As IDocumentInfo = TryCast(theMapDoc, IDocumentInfo)  Dim FileTitle as String = theDocInfo.DocumentTitle
I found that the IMap interface has a Description field, but from what I tried it doesn't seem to be the same one as in the form.
I was searching around online, but I cannot find any help in reading the Description field. Any help would be greatly appreciated.
Thanks in advance!
KenBuja
MVP Esteemed Contributor
The IDocumentInfo2 interface exposes much more information.
        Dim pMapDocument As New ESRI.ArcGIS.Carto.MapDocument         pMapDocument.Open("TheFileName.mxd")          Dim pDocInfo As ESRI.ArcGIS.Carto.IDocumentInfo2 = TryCast(pMapDocument, ESRI.ArcGIS.Carto.IDocumentInfo2)          Debug.Print(pDocInfo.Author.ToString & vbNewLine &                      pDocInfo.Category.ToString & vbNewLine &                      pDocInfo.Comments.ToString & vbNewLine &                      pDocInfo.Credits.ToString & vbNewLine &                      pDocInfo.DateExported.ToString & vbNewLine &                      pDocInfo.DatePrinted.ToString & vbNewLine &                      pDocInfo.DateSaved.ToString & vbNewLine &                      pDocInfo.DocumentTitle.ToString & vbNewLine &                      pDocInfo.Folder.ToString & vbNewLine &                      pDocInfo.HyperlinkBase.ToString & vbNewLine &                      pDocInfo.Keywords.ToString & vbNewLine &                      pDocInfo.Name.ToString & vbNewLine &                      pDocInfo.Path.ToString & vbNewLine &                      pDocInfo.RelativePaths.ToString & vbNewLine &                      pDocInfo.SavePreview.ToString & vbNewLine &                      pDocInfo.Subject.ToString                      )
The description is given in the Comments property.
KenBuja
JamesFinlay
That's exactly what I needed. I hadn't realized it was in the Comments property. Thank you very much for the help.
