how to texture random object
1438
12-18-2012 01:31 PM
anthonymagdelaine
all is in the title,
following this kind of idea, for parcels, garden, roofs, etc...
[ATTACH=CONFIG]20059[/ATTACH]
code used:
fileRandom("folders/images_**.obj")
what else ?
JoanneO_Brien
are the objects inserted randomly in the rulefile?
I think all you need would be
ObjectTex = fileRandom("folders/images_**.obj")
ObjectTexture -->
 alignScopeToGeometry(zUp,auto)
 setupProjection(0,scope.xy,'1,'1)
             projectUV(0)
 texture(ObjectTex)
although the number values etc will probably change for you but that's the idea...
anthonymagdelaine
yes the object are inserted with scatter
but the line you wrote: "texture(ObjectTex)" looks strange
it means i must call the object as texture?
i tested this and finally it searsh for an unknown texture
Tomb1 =  fileRandom("models/Cimetiere/Tomb_**.obj")
TombImport--> set(trim.vertical, false)
    s(0.3,0,0)
    i(Tomb1)
    texture("ObjectTexture")
ObjectTexture -->
           projectUV(0)
   texture(Tomb1)
anthonymagdelaine
i fund a way to distribute objects randomly without using random system and allowing me to keep textures to the right objects by using probability function
like that :
MiseEnPlace--> case p(0.1) : TombE1Import[Lot.]
  case p(TombType) : TombComp[Lot.]
  case p(TombType) : Tree[Lot.]
  case p(TombType) : TombComp2[Lot.]
  else : NIL [Lot.]
MatthiasBuehler1
Hi !
If each of those objects has it's own textures, just make sure you also have the .mtl file in the same spot as the .obj.
The .mtl file carries the material information such as the texture.
Otherwise, I may have an other useful way to solve your issue.
matt
