Search task that returns intersecting features?
5285
14
04-22-2016 12:09 PM
helenchu
What I'm trying to do is to have all intersecting points returned with the attribute grid view from a selected polygon.  Users click to select the polygon.  Is there a widget like that out there ?  Thanks.
RobertScheitlin__GISP
Helen,
  The eSearch widget allow you to draw a point on the map that will select a polygon and then use the "By Spatial" tab to select features that intersect the selected polygon. If you configure the search layer to be added as an operational layer and open in Attribute Table widget then the results will display in grid format in the Attribute Table widget.
Enhanced Search Widget Version 2.0.1 - 4/20/16
Helen,
helenchu
Thank you so much Robert.  I'll work on it.
helenchu
Hi Robert,
I followed the instructions http://www.tapasdas.com/WABv2.pdf to implement your widgets however I got the below error when I ran startup.bat.  Anything that I missed ?  Thankyou very much for your help.
In config.json I have:
  "geometryService": "http://srvarcdev.harriscad.org/arcgis/rest/services/Utilities/Geometry/GeometryServer",
The page opens fine.
In my WAB folder:
Helen,
  I have not seen that error before. I am not sure what to suggest besides install a fresh copy of WAB on your machine in a different folder try installing the eSearch widget again. You must have made a syntax error in some file.
helenchu
Thanks.  It's weird cuz I haven't touch any of those files at all.
So did you have WAB running before then?
helenchu
When I registered my app, everything went fine, no error, got my app ID.  However, when typed http://localhost:3344/ it returns error: "Unable to access http://srvarcdev.harriscad.org/arcgis A server with the specified hostname could not be found"
If I copy paste http://srvarcdev.harriscad.org/arcgis to browser it will auto redirect to http://srvarcdev.harriscad.org/arcgis/rest/services and this page shows up fine.
On this server I have portal set up http://srvarcdev.harriscad.org/portal/home/
and in the step to register my app, I have the URL http://localhost:3344/webappbuilder
Do you think the issue here is my url path ?  Thanks.
Thanks
Helen,
Is srvarcdev.harriscad.org a public facing url? When I try and go to it, I get an error.
I would change the GeometryService url back to the default of
"geometryService": "http://utility.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer",
helenchu
No it's internal not a public site.  When I typed or copy the url it does the redirect thing.  The page still shows up fine though.
http://srvarcdev.harriscad.org/arcgis/rest/services?redirect=http://srvarcdev.harriscad.org/arcgis/r...
I changed the url back to default as you advised.  Same error!
When I run startup.bat as administrator, I got " "server" directory does not exist"
Thank you
