Roberts Custom WAB Widgets
406722
475
12-31-2014 11:28 AM
GilbertoMatos
Hello!
Robert, how do I in the search widget to enter the geographic coordinates, and does it point and buffer for them? This without having to click on a point.
Thank you!
RobertScheitlin__GISP
Gilberto,
   No there is not a way to manually enter coordinates and have it buffer those.
GilbertoMatos
Ok
I need this functionality. Where do you suggest I should customize? Do you have any tips so I can do this?
Thank you!
Gilberto,
   You would add some html text inputs to the Widget.html and then your code to handle the graphic generation to the Widget.js. I have not had the need for this so don't have much more advice off hand.
GilbertoMatos
Ok Robert!
Thank you very much. I'll see what I can do.
hug
NhuMai
Robert,
Can these widgets be integrated into a custom javascript app that doesn't use WAB? If so, what's the best way of going about it?
No they can not.
kitkagergely1
Hello Robert!
This is my first event in this forum. I need some help.
I use the WAB Edit custom widget, but i don't find, where i can configure the required option for a attribute.
In the Flex I could it (that was an option, and I could turn on), but in the WAB not. I wouldn't use the Smart edit ( in this is it possible to give an expression) widget, because the basic Edit widget is better to my goals.
Thank's
Gergely
Gergely,
I am not aware of a custom edit widget.
Setting a Feature Server Services field to nullable true or false is how that is handled in the JS world not in some widget configuration.
kitkagergely1
Thank's it is working.
Gergely
