Roberts Custom WAB Widgets
407585
475
12-31-2014 11:28 AM
LandonWiedenman1
Hi Robert, thanks for putting together these widgets.
It would be great to build a better time slider widget -- where you can update the time extent in the widget.  Currently that's missing and makes the time slider not very useful.
Dunn_Jeremy
Morning Landon,
Did you get a solution to this issue ? I'm interested to know if the time slider can be honoured by the summarize widget. Have you encountered this issue before ?
Regards.
Jeremy.
RobertScheitlin__GISP
Jeremy,
  Unfortunately those widgets do not respect the time sliders time extent and would take a good deal of work to make them do that. You will need to request enhancements for those widgets to be time aware.
LandonWiedenman1
Hi Jeremy,
I have not found a resolution yet — but I haven’t been working on it. Please let me know if you figure it out!
RodWoodfordOld
Hi Robert,
Sorry to hassle you. Will the current versions of your widgets work with WABD 2.2?
Rod
Rod,
   Eventually I will be doing 2.2 version but yes the 2.1 versions will work fine in WAB 2.2
GilbertoMatos
Hello! Is there a widget for version 2.1 of the web appbuilder that runs buffer? I need to request some parameters for the user, among them the distance, and after, I have to circulate the area referring to the radius of the point found on the map. I tried using the geoprocessing widget, but I was not successful. Thanks for any help.
Gilberto,
   The eSearch widget allows you to buffer a point clicked on the map or a feature selected by a query.
GilbertoMatos
Many thanks Robert. I'll check. hug
BarnabyRockwell
Robert,
This is great.  I guess I'll have to try out eSearch!
Cheers,
Barnaby
