Roberts Custom WAB Widgets
407934
475
12-31-2014 11:28 AM
RobertScheitlin__GISP
Mikkel,
   So your having problems with my widgets or are you talking about your own widget development. There is nothing that needs to be changed in my widgets to get them running.
MikkelHylden
It's been a little of both - I can get a custom widget to display including with a dijit combobox now, as long as I'm not trying to also load the jquery library in the declare statement:
     'jimu/loaderplugins/jquery-loader!https://code.jquery.com/jquery-git1.min.js',
This I find strange because the same line works fine in the UseJQuery sample widget.
Yesterday, I tried to put your Identify (copied in the whole directory) in the directory:
     C:\arcgis-web-appbuilder-1.2\client\stemapp\widgets\samplewidgets
The identify icon then comes up in the webappviewer toolbar as expected, but will not execute.  The only message the displays is a popup that says "Create widget error: Widgets\samplewidgets\Identify\Widget"
I'm continuing to wade through all this, but just wanted to see if that was something that had come up in the past. I'm guessing just I have some configuration item set incorrectly, as all the tutorials appear to make it fairly easy to build custom stuff.
Mikkel,
    Add all my widget to the root widgets folder and not a sub folder like samplewidgets as this could affect the codes path.
MikkelHylden
Yep, putting the identify in the root did the trick. Thanks very much.
Mikkel
MikkelHylden
One other note - the jqeury and dijit work ok together, but apparently the order in which the declare statements are added matters - the dijit needs to come AFTER the jquery:
define(['dojo/_base/declare',
    'jimu/BaseWidget',
    'dijit/form/ComboBox'
AdamChavez
Good Afternoon,
     I have a need to modify the WAB site to zoom to my current coordinate(GPS) as soon as the site loads, is this possible?
Adam,
   How are you getting the GPS coordinates?
AdamChavez
Clicking once on the MyLocation widget, is there a way to call that “click” when the Web App opens to automatically zoom to location without having to put tons of extra code into the web app?
IT Analyst – Database (SQL)
Information Services Division
Internal Services Department
E-mail:- [email protected]<mailto:[email protected]>
Phone:- 559-600-5881
Adam,
   Yes it would be possible. I will have to look at the amount of code involved in this and get back to you.
AdamGebhart
Robert Scheitlin, GISP
I believe you created the Basemap Switcher widget for Flex.  Am I correct, and if so, do you have any plans to create it in WAB?  Just curious as our Flex site includes that widget and our users, as well as staff, really like it.
Thanks.
