Roberts Custom WAB Widgets
407974
475
12-31-2014 11:28 AM
GeorgeKatsambas
yes noticed that there are files all over, guess I will learn to live with the defaults for now.
DanielStoelb
So if someone was wanting to change the width of the icons in the header controller widget, where would they do that?
RobertScheitlin__GISP
Daniel,
   Just add this rule css to your themes common.css file (standard default is 24 x 24)
.jimu-widget-header-controller .icon-node img {
    height: 34px;
    width: 34px;
You will have to make other adjustments to suit your liking though.
DanielStoelb
Is it possible to have one widget icon in the header controller to be larger than the others - for example, keep the same height for all, but one widget be wider than the others?
JacquelineKovarik
Hi Robert,
Great widgets - thanks for sharing with the GIS Community!
I'm using your Enhanced Search tool in one of my web apps, and am wondering if there's a trick to get related tabular information to display from the pop-up generated after using the Search by Shape tool?
When I click on a feature within the selection set (from the Results window within the Enhanced Search tool), a pop-up shows up with the standard "Show Related Records" link. When I click on this link, the related table appears to open, but never loads at the bottom of the page.
When I click on a feature (not using your Enhanced Search tool), I can use the "Show Related Records" link to access the related table from the feature's pop-up...
Thanks in advance for your help!
Jacqueline
Jacqueline,
   Something has changed in WAB 1.2 and I will need to fix this. Hopefully I will have it fixed in the next release.
JacquelineKovarik
Ok - thank you for letting me know! I thought it was user error on my end.
Thanks again for sharing the great widgets you've created!
Jacqueline
All,
   Another new widget added to my collection. Check out the Enhanced Bookmark Widget.
SherieTaylor
Wondering if you know of a way to create a drop down pick list when using the Search widget in web app builder?  Ex:  I have the Tax Unit layer searchable by the Tax Unit field but the user must know the Tax Unit # instead of being able to select it from a pick list.
Sherie,
   I take it you have not seen the widgets help documentation.
Web AppBuilder for ArcGIS | Help - Enhanced Search widget
