Roberts Custom WAB Widgets
337807
475
12-31-2014 11:28 AM
RobertScheitlin__GISP
DavidDas__GISP
Hi Barnaby,
You are correct. The Google Street View Widget 1.1 is not working in IE for me either.
I made a test case here:
http://www.tapasdas.com/Maps/Phones/app16/
When I try to run this application in IE and activate the Google Street View Widget, I get this error message:
checkForSVpano: ‘console’ is undefined
However, as you said, this works fine in Chrome and Firefox.
Best regards,
Tapas Das
GIS Programmer/Analyst
Maricopa County
602.506.1088
BarnabyRockwell
Hi Tapas,
Yep, that's the error I get.
Cheers,
Barnaby
Guys not sure what issue you are running into then. I just tested my live preview site in IE 11 with out issue as seen here:
Are you guys talking about running the street view widget from an app that has not been deployed yet and is still running in NodeJS?
EDIT: Nope I tested it in a non deployed app in NodeJS using IE 11 and it was fine too.
DavidDas__GISP
Hi Robert,
I am getting the error message on IE 9. Perhaps this is fixed in IE 11.
I am including a screenshot.
This happens when you try to drag the Google Pegman Tool on to a street.
No, I am not running the application from within the Web AppBuilder. I have downloaded the app as a ZIP file and deployed it on my test server:
http://www.tapasdas.com/Maps/Phones/app19/
Tapas
Tapas,
  Opening the developer tools in IE (F12) what document mode are you seeing?
DavidDas__GISP
Robert,
When I press to open Developer Tools, I see that the Document Mode = IE9 Standards
Tapas
Tapas,
   OK, I did some research and IE (the usual culprit) does not recognize console unless the developer tools window is already open. So a quick fix is to open StreetView.html and comment out any console.info lines I have in the code. I will get this fixed for the next release.
DavidDas__GISP
Robert,
Your Google Street View Widget works just fine in IE9 using your FlexViewer Version within a FlexViewer 3.6 template.
http://www.tapasdas.com/Maps/Desktops/web8/
Tapas Das
Maricopa County
602.506.1088
BarnabyRockwell
Robert,
In IE11 main browser window, I get Edge (default) just like you.  In the pop-up window, I get this:
Edit:  Yep, there was one un-commented console.info line.  Once that was commented out, the error goes away and all is good.
BarnabyRockwell
Robert,
Since I installed StreetView 1.1, I have noticed this weirdness in the panorama display in IE11.  Note displacement of navigation tools at upper left.  I notice from your image posted above that you don't have this issue in IE.
Any ideas?
Best regards,
Barnaby
