All,
I just installed WAB 1.1 Developer Edition and went through the instructions for loading the custom widget, however a few things popped up:
1. There is no \client\builder\predefined-apps\default2DApp\ folder. I did find a config.json file in client\stemapp\predefined-apps\default so I added the code to this file.
2. I can load the widget and connect to my services, but once I have them added, nothing is actually added to the map. So there is very clearly something still wrong.
Has anyone had this issue, or know what I could be doing wrong? I don't have a proxy as my services are not secured, and are actually on the same test machine as the WAB.
Thanks!
Leah,
You might want to check out this post for details: Tips for using the custom LocalLayer widget with WAB-Dev edition
It seems to me the issue is related to where you added the widget in your json code. I documented how I did the install, which is working for me. Here are the details:
Leah,
I did all of this and read through the document. Do you have that default2D folder in your directory?
This is where I found the config...since there was no pre-defined apps folder in my other location:
I do not have the default2D folder.
Here is the modification that I made in the cofig.json file in the client\stemapp\predefined-apps\default\config.json file:
"widgetOnScreen": {
"widgets": [{
"uri": "widgets/LocalLayer/Widget",
"visible": true
Okay, I re-did everything and it is working now!!! Thanks for the very quick reply!!
