LocalLayer Widget not working
4581
06-26-2015 02:23 PM
LeahSaunders
All,
I just installed WAB 1.1 Developer Edition and went through the instructions for loading the custom widget, however a few things popped up:
1. There is no \client\builder\predefined-apps\default2DApp\ folder.  I did find a config.json file in client\stemapp\predefined-apps\default so I added the code to this file.
2. I can load the widget and connect to my services, but once I have them added, nothing is actually added to the map.  So there is very clearly something still wrong.
Has anyone had this issue, or know what I could be doing wrong?  I don't have a proxy as my services are not secured, and are actually on the same test machine as the WAB.
Thanks!
DanielStoelb
Leah,
You might want to check out this post for details: Tips for using the custom LocalLayer widget with WAB-Dev edition
It seems to me the issue is related to where you added the widget in your json code. I documented how I did the install, which is working for me.  Here are the details:
  • This widget updates the interface to allow for local layers to be added into the system
    • Tips and tricks for implementation can be found here: https://community.esri.com/blogs/myAlaskaGIS/2015/02/04/tips-for-using-the-custom-locallayer-widget-...
    • Must click the visibility icon to make it applicable within the application
    • References to the widget must be added manually into the config.json file
      • § Make sure visible=true
    • Two changes are needed within the client\stemapp\jimu.js\LayerInfos\LayerInfoForMapService.js file:
      • § For version 1.1 Line 450 should be changed from:
        • var url = this.originOperLayer.url + '/' + subId;
      • § To:
        • var url = this.originOperLayer.layerObject.url + '/' + subId;
      • § for v1.1 And line 423 should be changed from:
        • var url = this.originOperLayer.url + '/layers';
      • § To:
        • var url = this.originOperLayer.layerObject.url + '/layers';
DanielStoelb
Leah,
      • § To:
      • § To:
LeahSaunders
I did all of this and read through the document.  Do you have that default2D folder in your directory?
This is where I found the config...since there was no pre-defined apps folder in my other location:
DanielStoelb
I do not have the default2D folder.
Here is the modification that I made in the cofig.json file in the client\stemapp\predefined-apps\default\config.json file:
"widgetOnScreen": {
    "widgets": [{
      "uri": "widgets/LocalLayer/Widget",
      "visible": true
LeahSaunders
Okay, I re-did everything and it is working now!!!  Thanks for the very quick reply!!
DanielStoelb
No problem!
