Geoprocessing Widget - Don't See Outputs
4933
14
02-06-2018 06:25 AM
ChrisHolmes
Hello everyone,
I have a script in arcmap which operates on selected blocks on the map and does some calculations and then displays results like this:
I had the script (python toolbox) published as a gp service so I could use it from the geoprocessing wizard. It seems to "validate" ok when I enter the url to the service. It shows absolutely nothing for inputs/outputs/options. I'm using the select widget to select the blocks on the land use layer then clicking the geoprocessing widget then execute.
This is what happens in web appbuilder:
I really have no idea what's going on with it in web appbuilder. I know that in arcmap the script knows to look at the land use layer for selected blocks and then it does its calculations. Not quite sure at the moment how to move forward with getting this working. Any help appreciated.
ChrisHolmes
Hi Kevin, I do not know why I was not able to see "set as input to geoprocessing".
ChrisHolmes
So thought I'd update where things are at with this. Getting closer but still not working. I changed the code as follows so that the toolbox has inputs and outputs (code at bottom).
When I use the select widget to select blocks it seems as if the selection is not being used as input to the gp widget.
As you can see from the gp results it is using 33291 blocks in the calculations (the layer has a total of 34646 blocks). So I'm not sure where the 33291 is coming from.
Also I thought I would see "Set as input of geoprocessing" as a select option, but I only see the following:
Any thoughts appreciated as to what I may be missing to get the gp widget to use the selected blocks. Hoping we're getting close. Thanks everyone!
###Start of class for DiversityIndex toolbox
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "DiversityIndex"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [DiversityIndex]
class DiversityIndex(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Diversity Index"
        self.description = "Calculate the land use diversity index based on selected blocks."
        self.canRunInBackground = False
    def getParameterInfo(self):
        #Define parameter definitions
        # First parameter
        param0 = arcpy.Parameter(
            displayName="Input Features",
            name="in_features",
            datatype="GPFeatureLayer",
            parameterType="Required",
            direction="Input")
        param0.value = 'LandUse_UseCategory'
        # Second parameter
        param1 = arcpy.Parameter(
            displayName="Diversity Index",
            name="diversity_index",
            datatype="GPDouble",
            parameterType="Derived",
            direction="Output")
        # Third parameter
        param2 = arcpy.Parameter(
            displayName="Residential Diversity Index",
            name="residential_diversity_index",
            direction="Output")
        # Fourth parameter
        param3 = arcpy.Parameter(
            displayName="Total Blocks Selected",
            name="total_blocks_selected",
            datatype="GPLong",
            direction="Output")
        # Fifth parameter
        param4 = arcpy.Parameter(
            displayName="Total Blocks Area",
            name="total_blocks_area",
            direction="Output")
        # Sixth parameter
        param5 = arcpy.Parameter(
            displayName="Total Residential Blocks Selected",
            name="total_residential_blocks_selected",
            datatype="GPLong",
            direction="Output")
        # Seventh parameter
        param6 = arcpy.Parameter(
            displayName="Total Residential Blocks Area",
            name="total_residential_blocks_area",
            direction="Output")
        # Eighth parameter
        param7 = arcpy.Parameter(
            displayName="Note",
            name="note",
            datatype="GPString",
            direction="Output")
        param7.value = 'NOTE: Any blocks with a use category of Invalid are not included in any calculations.'
        params = [param0, param1, param2, param3, param4, param5, param6, param7]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        import numpy as np
        try:
          inFeatures = parameters[0].valueAsText
          #Create in memory tables:
          arcpy.CreateTable_management("in_memory", "tableSelRecs")
          arcpy.AddField_management(r'in_memory\tableSelRecs', "USE_CATEGORY", "TEXT", field_length=35)
          arcpy.AddField_management(r'in_memory\tableSelRecs', "SHAPE_Area", "Double")
          arcpy.CreateTable_management("in_memory", "tableSumRecs")
          arcpy.AddField_management(r'in_memory\tableSumRecs', "USE_CATEGORY", "TEXT", field_length=35)
          arcpy.AddField_management(r'in_memory\tableSumRecs', "SHAPE_Area", "Double")
          totalArea = 0
          totalResArea = 0
          totalParcels = 0
          totalResParcels = 0
          #use da.SearchCursor to access necessary fields from selected records
          with arcpy.da.SearchCursor(inFeatures,['USE_CATEGORY','SHAPE@AREA']) as cursor:
              #Setup insert cursor to insert selected polygons into tableSelRecs
              insCursor = arcpy.da.InsertCursor(r'in_memory\tableSelRecs', ['USE_CATEGORY','SHAPE_Area'])
              #Isert selected rows into insCursor; Get total area of selected records; Get a count of total parcels
              for row in cursor:
                  if row[0] != 'Invalid':
                      insCursor.insertRow((row[0],row[1]))
                      totalArea += row[1]
                      totalParcels += 1
                  #If the block is of a 'Residential' USE_CATEGORY type then add that value into the Residential DI calculation variable
                  if row[0] in('Residential - Low Density','Residential - Medium Density','Residential - High Density'):
                      totalResArea += row[1]
                      totalResParcels += 1
              #use summarystatistics against tableSelRecs to get totals per USE_CATEGORY and write results to tableSumRecs
              arcpy.Statistics_analysis(r'in_memory\tableSelRecs', r'in_memory\tableSumRecs', [["SHAPE_Area", "SUM"]], "USE_CATEGORY")
          with arcpy.da.SearchCursor(r'in_memory\tableSumRecs',['USE_CATEGORY','SUM_SHAPE_Area']) as selCur:
              #list to store calculation for each USE_CATEGORY value used in DI calculation
              interimValue = [0]
              #list to store calculation for each USE_CATEGORY value used in RDI calculation
              interimResValue = [0]
              for sRow in selCur:
                  #divide the USE_CATEGORY area by the total community area then square that number & append it to the list
                  interimValue.append(np.square(sRow[1]/totalArea))
                  if sRow[0] in('Residential - Low Density','Residential - Medium Density','Residential - High Density'):
                      interimResValue.append(np.square(sRow[1]/totalResArea))
              #sum the values in the list then subtract that value from 1 to get the DI for the selected blocks
              DI = 1 - sum(interimValue)
              #sum the values in the list then subtract that value from 1 to get the RDI for the selected blocks
              RDI = 1 - sum(interimResValue)
              parameters[1].value = DI
              parameters[2].value = RDI
              parameters[3].value = totalParcels
              parameters[4].value = totalArea
              parameters[5].value = totalResParcels
              parameters[6].value = totalResArea
          #Delete in memory tables
          arcpy.Delete_management(r'in_memory\tableSelRecs')
          arcpy.Delete_management(r'in_memory\tableSumRecs')
        except arcpy.ExecuteError:
          print(arcpy.GetMessages(2))
KevinBell1
Get this working?  I'm about to start on a similar project!
ChrisHolmes
Hi Kevin, unfortunately as yet I haven't made much more progress from what you see here. It got frustrating on my end trying to troubleshoot this as I do not have permission to publish services in our environment and it requires putting in a helpdesk ticket to IT and it just got bottlenecked with me making repeated requests to republish or refresh the service. So I've put it aside for a bit and am trying to get them to give me permissions to publish services to our dev environment. Sorry I haven't better news for you. Once I'm back on track I'll update this thread.
KevinBell1
I'll update this thread with any progress on my end.  Thanks!
