Hello everyone,
I have a script in arcmap which operates on selected blocks on the map and does some calculations and then displays results like this:
I had the script (python toolbox) published as a gp service so I could use it from the geoprocessing wizard. It seems to "validate" ok when I enter the url to the service. It shows absolutely nothing for inputs/outputs/options. I'm using the select widget to select the blocks on the land use layer then clicking the geoprocessing widget then execute.
This is what happens in web appbuilder:
I really have no idea what's going on with it in web appbuilder. I know that in arcmap the script knows to look at the land use layer for selected blocks and then it does its calculations. Not quite sure at the moment how to move forward with getting this working. Any help appreciated.
