Anyone have any luck running the latest 2.8.1 on Portal 10.6?
I first tried copying "projection.js" and its dependencies "pe.js", "GeographicTransformation.js" and "GeographicTransformationStep.js" to the local widget folder. Changed all the define references to that local folder. But that errored in widget.js at the line "projection.load()" saying load was not a function and the debugger just said the projection object was a value of "3", odd. So then reset the references and copied the files to the Portal server. This got a step farther as the projection object seemed meaningful, but somewhat similar it gave an error that "g.load" is not a function. That was in "projection.js" this time.
Any thoughts? Is trying to mash up JSAPI 3.22 with a few 3.24 bits a bad idea?
