Adding Custom Graphic As Operational Layer
5889
11-14-2015 04:43 PM
DouglasLong
Hi Folks,
Problem: I have built a custom widget that creates a pre-defined custom graphic and adds to map, I need to be able to create a layer for this in the layer list (shows up in the layer list widget) such as "Custom Graphic", and be able to consume this in a geoprocessing widget (by selecting a layer from the map).
Issue
just wondering if anyone has done something similar,
I have modified the draw widget so that it creates custom shapes with different javascript algorithms,
so far it has been pretty simple to draw the custom shapes, but I want to add them to the map (Layer List), but have them be their separate entity, currently the draw result shows this (image below)
and in any geoprocessing widget, the draw_results will not load in the drop down by a geoprocessing tool (see such parameter below)
therefore I am unable to actually consume that polygon graphic in a geoprocessing tool,
in the image below is shows I want the custom graphic to show up
please, any help would be much appreciated. If someone can crack this, I will send them a Six Pack of beer, or maple syrup from Canada.
DouglasLong
seems that the other post is pretty accurate, as Robert Scheitlin pointed out, the query results used the following javascript to add the custom layer.
_createQueryResultLayer: function(){
        var resultLayer = null;
        var symbol = symbolJsonUtils.fromJson(this.currentAttrs.config.resultsSymbol);
        var renderer = new SimpleRenderer(symbol);
        if (this.cbxOperational.checked) {
          //new a feature layer
          var layerInfo = lang.clone(this.currentAttrs.layerInfo);
          var queryName = this._getBestQueryName(this.currentAttrs.config.name || '');
          //override layerInfo
          layerInfo.name = queryName;
          //ImageServiceLayer doesn't have drawingInfo
          if(!layerInfo.drawingInfo){
            layerInfo.drawingInfo = {};
          layerInfo.drawingInfo.renderer = renderer.toJson();
          layerInfo.drawingInfo.transparency = 0;
          layerInfo.minScale = 0;
          layerInfo.maxScale = 0;
          layerInfo.effectiveMinScale = 0;
          layerInfo.effectiveMaxScale = 0;
          layerInfo.defaultVisibility = true;
          //only keep necessary fields
          var necessaryFieldNames = this._getOutputFields();
          layerInfo.fields = array.filter(layerInfo.fields, lang.hitch(this, function(fieldInfo){
            return necessaryFieldNames.indexOf(fieldInfo.name) >= 0;
          var featureCollection = {
            layerDefinition: layerInfo,
            featureSet: null
          resultLayer = new FeatureLayer(featureCollection);
        } else {
          //use graphics layer
          this._resetAndAddTempResultLayer();
          resultLayer = this.tempResultLayer;
        this.currentAttrs.query.resultLayer = resultLayer;
        this.queryResults.resultLayer = resultLayer;
        //set renderer
        resultLayer.setRenderer(renderer);
        return resultLayer;
DouglasLong
this could be a possible answer, still looking for suggestions though, while I test this
Adding a Graphic Layer to the LayerList widget
DouglasLong
            featureSet: null
        } else {
        //set renderer
        return resultLayer;
