Can I change the icon of the widget group in Launch Pad theme?
4031
6
04-12-2016 03:08 PM
JakeCliffton
I would like to change the icon of the widget group: need to change the folder icon to the query icon.
But the Develop Edition does not provide any options for that. Can I change it from the source code somewhere? Thanks a lot!
RobertScheitlin__GISP
Jake,
  Sure just change or edit the group_icon.png:
[install dir]\server\apps\[app #]\themes\LaunchpadTheme\widgets\AnchorBarController\images\group_icon.png
C_EHoward
Is there any way to change the folder icon if you a have more than one group? I'd like to have a few widget groups with different icons for each group if possible so its easier to distinguish types of tools.
also- is there a place to see the images used for each widget? I started my app in AGOL and then imported to the dev edition so I am not sure where to look for this stuff
thanks
C E,
  You would have to do some extensive development to have a specific icon for individual groups (I have not had a need to attempt this so I don't have any code for this). The icons for each widget are inside the widgets folder in the images folder (called icon.png).
C_EHoward
Thanks Robert-- that's kinda what I thought in terms of the amount of effort it would take. I'll stick with my original plan to make unique-looking custom icons for each type of tool to differentiate and save the folder for something more generic. thanks for the quick response.
LefterisKoumis
You can change the icon of groups by adding the code after line 20.
    _addDefaultOfWidgetGroup: function(config){
      //group/widget labe, icon
      jimuUtils.visitElement(config, lang.hitch(this, function(e, info){
        e.isOnScreen = info.isOnScreen;
        if(e.widgets){
          //it's group
          e.gid = e.id;
          if(e.widgets.length === 1){
            if(!e.label){
              e.label = e.widgets[0].label? e.widgets[0].label: 'Group';
            if(!e.icon){
              if(e.widgets[0].uri){
                e.icon = this._getDefaultIconFromUri(e.widgets[0].uri);
              }else{
                e.icon = 'jimu.js/images/group_icon.png';
          }else{
               if (e.label === "my group"){
                    e.icon = 'jimu.js/images/mylogo.png';
               } else if (e.label === "my group1") {
               e.icon = 'jimu.js/images/mylogo1.png';
               //add as many custom groups icons you wish....
               else {
                    e.icon = e.icon? e.icon: 'jimu.js/images/group_icon.png';
                    e.label = e.label? e.label: 'Group_' + info.index;
        }else{
          e.gid = info.groupId;
AldwinGregorio
Have you tried adding icon and your icon location in your main config? Something like this.
