GeoEvent Processor Data Requirements
1748
07-24-2018 06:12 PM
SvetlanaTaylor
Hi Esri Community,
Could someone please explain how data is downloaded into ESRI GeoEvent Processor from another server? Are there requirements that the other server needs to fulfill?
Thanks!
XanderBakker
Esri Esteemed Contributor
Can you elaborate a little more about how your current infrastructure is? What type of data should the GeoEvent Server ingest? Does the server where GeoEvent is installed have access to read the data from the other server? What version of the software are you using?
SvetlanaTaylor
Xander, thanks for responding! I will have to check on the access to other servers. The data would be hourly measurement from three water quality sensors.
Get Outlook for iOS<https://aka.ms/o0ukef>
XanderBakker
The sensor data is stored as CSV files?
RobertKrisher
I'd recommend take a look at the different types of input connectors ( Input connectors—Real-time Data Feeds and Sensors (10.6) | ArcGIS Enterprise  ) that GeoEvent server offers.  These can allow you to pull data from other systems using flat files, web calls, and many other methods.  It sounds like you're trying to extract information from some kind of SCADA system, depending on the software being used to store the data you may be able to use certain apis or products to accomplish this.  As an example, if the data is being stored in OSIsoft's PI Historian, they have a product that allows you to publish real time feature layers from your SCADA data that can be read directly by the GIS.
