Edit Hydrant Maintenance Inspection Table
1453
07-11-2023 08:12 AM
Labels (3)
VillageOf_Lake_Placid
I work for a small utility and have implemented the Water Utility Hydrant Inspections solution. I can't seem to figure out how to edit or modify the related record table Hydrant Maintenance Inspection. I would like to add a few additional fields to the survey but can't figure out how to actually edit the table.
JoelSmith3
Esri Alum
Hi, Sorry for the delay! Send me an email and I can look into this with you.
j.smith@esri.com
Thanks!
Joel
Ivy_Hinson
I have a similar issue with adding fields to an attribute table in Water Utility Solutions.
Joel and I were able to figure out a fix for this.
I haven't had time to write up what we did so feel free to contact me at Pwells@villageoflakeplacid.ny.gov and I can walk you though the process.
