Attribute Assistant Update Linked Record Value Method
7252
14
05-24-2013 01:04 PM
ZachLawson
My office maintains a point feature class of all of our force main air release valves and a separate table with all the maintenance/inspections/etc done on these ARVs. What I want to happen is when a new maintenance item (a new row) is added to my ARV_Maintenance table, the Last_Inspection_Date field of my ARV feature class is updated with the date from the Inspection_Date field of the new row. It seems that UPDATE_LINKED_RECORD should do what I want, but I can't get it to work. I'm currently trying (and some variations thereof):
Table Name: ARV_Maintenance
Field Name: Inspection_Date
Value Method: UPDATE_LINKED_RECORD
Value Info: ARV|Last_Inspection_Date|Unique_ID|Unique_ID
What am I missing here?
MikeMillerGIS
Esri Frequent Contributor
That is a very old version, please update to the latest and try again
JustinFlannery3
Ahh, works like a charm now.  I was loading my Add-Ins from a folder for an old version of ArcMap ... Thanks for helping me pinpoint that.
AlinaTaus
I am trying to accomplish something similar but I want to populate the Last Inspection Date in my asset feature class with the year (YYYY format). Is there a way to set up this method to return just the year part from a date field?
Thanks!
MikeMillerGIS
This method will pull the value to the source feature, you could then set up expression to pull out only the date.
AlinaTaus
Thank you Mike. My problem is the Last Inspection Date field is only 4 characters long so I can't store the date in it. I was hoping I could combine an expression into this method but I guess that won't work. I think I will have to create a new field.
