New password for Arc Hydro ftp site - October 1st 2013
9081
26
10-01-2013 07:26 AM
ChristineDartiguenave
Note that the password has changed as of 10/1/2013 (will be reset every 6 months). The new password is:
ADSRiver.2013b
Christine Dartiguenave
Esri Water Resources Team
https://mft.esri.com
Login: ADSRiverHydraulics
Password: ADSRiver.2013b
To access, select a FTP client:
1. Web Client
Site link: https://mft.esri.com
(Video tutorials available on the main page, prior to log in)
2. Third party SFTP client
** Download a preconfigured client
https://mft.esri.com/EFTClient/Account/mft.zip **
3. FTP address to configure a third party SFTP client of your choice:
Site address: mft.esri.com
Port: 22
Avrikadmon
Hi
I used the usernsme and the password ADSRiverHydraulics ADSRiver.2013b, but it doesn't open.
Is the password replaced ?
Thanks for help
Avri
AdrianneBlack
I can't seem to log on today either. This is the message I get from FileZilla:
[INDENT]Status: Connecting to mft.esri.com...
Response: fzSftp started
Command: open "ADSRiverHydraulics@mft.esri.com" 22
Command: Pass: *************
Error: Authentication failed.
Error: Critical error
Error: Could not connect to server[/INDENT]
This is the message I get through MFTAccount/WinSCP:
[INDENT]Disconnected: No supported authentication methods available (server sent: )
Authentication log (see session log for details):
Using username "ADSRiverHydraulics".
Access denied.
Authentication failed.[/INDENT]
V_StuartFoote
Please have another go, accessed minutes ago without issue with credentials as listed in OP.
Stuart
Avrikadmon
Hi Stuart
I did as you said.
Looks very nice both Hydro Tools and GeoHMS.
Avri
RichardStevens1
I have been trying for two days to connect with multiple clients with no luck. As far as I can tell my settings are correct. I repeatedly get this error:
Error: Server unexpectedly closed network connection
I'm currently trying with Firezilla and am using these settings:
Host: mft.esri.com
Port: 22
Protocol: SFTP
User: ADSRiverHydraulics
Pass: ADSRiver.2013b
I'm in desperate need of this new version. Any suggestions or another source for the MSI. I'd be willing to pay someone to email it to me at this point. Laugh!
RichardStevens1
I have up and spoke to one of our IT guys and he connected and downloaded it without issue. Laugh.
zachswander
Alright, so I am having a similar yet different problem, which I posted on the v 2.0 release blog. Every time I try to connect using FileZilla, it is replying that the "connection refused" and "could not connect to server". I have tried using the settings manager and the quick connect lines, but no luck. Is there some sort of maintenance going on?
MarkBoucher
Honored Contributor
I tried it and had the same error, but then took out the "http://" part of "https://mft.esri.com" and FileZilla worked fine.  FileZilla did add the "sftp://" text in front of mtf.esri.com. I also put in Port 22, but FileZilla erased that even though it used it.
[ATTACH=CONFIG]30831[/ATTACH]
Janezg
I am looking version for ArcGIS 9.3
ftp folder /incoming/arcHydro/Setup9.3_9.3.1/1.4.0.258 is unfortunately empty.
The setup should be there now.
Christine
