New password for Arc Hydro ftp site - October 1st 2013
8640
26
10-01-2013 07:26 AM
ChristineDartiguenave
Note that the password has changed as of 10/1/2013 (will be reset every 6 months). The new password is:
ADSRiver.2013b
Christine Dartiguenave
Esri Water Resources Team
https://mft.esri.com
Login: ADSRiverHydraulics
Password: ADSRiver.2013b
To access, select a FTP client:
1. Web Client
Site link: https://mft.esri.com
(Video tutorials available on the main page, prior to log in)
2. Third party SFTP client
** Download a preconfigured client
https://mft.esri.com/EFTClient/Account/mft.zip **
3. FTP address to configure a third party SFTP client of your choice:
Site address: mft.esri.com
Port: 22
SumitJain
Heres the error message in filezilla.. i am entering the new password ADSRiver.2013b... can somebody help
Status: Connecting to mft.esri.com...
Response: fzSftp started
Command: open "ADSRiverHydraulics@mft.esri.com" 22
Command: Pass: **************
Error: Disconnected: No supported authentication methods available (server sent: )
Error: Could not connect to server
Status: Waiting to retry...
V_StuartFoote
No change, just verified the posted remains viable.  Try it again.
Stuart
liulang7106liulang7106
I tried it and had the same error, but then took out the "http://" part of "https://mft.esri.com" and FileZilla worked fine.  FileZilla did add the "sftp://" text in front of mtf.esri.com. I also put in Port 22, but FileZilla erased that even though it used it.
[ATTACH=CONFIG]30831[/ATTACH]
same question as me, Can anybody post the install-file link to me? Thanks in advance
VikramSinha
I am getting a 'authentication failed' error for last 3 days or so.
Error: Authentication failed.
Error: Critical error
Is there a new password, or am I missing something while trying to connect? These parameters worked just fine for me last week.
Thanks.
Sinha
MarkBoucher
Honored Contributor
I just tried with Filezilla and got in:
Echo from FileZilla
Status:    Connected to mft.esri.com
Status:    Retrieving directory listing...
Command:    cd "/incoming/arcHydro"
Response:    New directory is: "/incoming/arcHydro"
Command:    ls
Status:    Listing directory /incoming/arcHydro
Status:    Calculating timezone offset of server...
Command:    mtime "Data"
Response:    1391610761
Status:    Timezone offsets: Server: -25200 seconds. Local: -25200 seconds. Difference: 0 seconds.
Status:    Directory listing successful
The basic protocols I use are posted here http://forums.arcgis.com/threads/48100-ArcHydro-Problem-Solvers?p=372960&viewfull=1#post372960
Make sure the protocol type is SFTP - SSH File Transfer Protocol. This is an option in FileZilla "File>Site Manager..." dialogue window. Messed me once.
BenjaminMittler
When i put in the password it is telling me that further authentication is required. Did the password change or am i just doing something wrong?
