Failed to execute Generate CNGrid
4371
6
11-03-2018 08:07 AM
renzsamonte
Hi!
I have encountered errors during generation of CN grid like Failed to execute (Generate CNGrid). But when I opened the attribute table of the merged land use and soil data to check if I missed something, there is an added column for CN and has value in it. Can somebody please explain what this means? Can I trust and use this result?
Thank you very much.
Sincerely,
Florence
KurtisBaron
Florence,
Can you sample a handful of locations and check the land use and soils and the CN grid and check the lookup table to see if there's agreement?
Kurt
renzsamonte
Kurtis Baron,
Good day to you Sir!
May I know what it means by "agreement" in the land use and soils and CN grid?
Florence
On Tuesday, 6 November 2018, 11:55:58 PM GMT+8, Kurtis Baron <[email protected]> wrote:
#yiv7241900360 * #yiv7241900360 a #yiv7241900360 body {font-family:Helvetica, Arial, sans-serif;}#yiv7241900360 #yiv7241900360 h1, #yiv7241900360 h2, #yiv7241900360 h3, #yiv7241900360 h4, #yiv7241900360 h5, #yiv7241900360 h6, #yiv7241900360 p, #yiv7241900360 hr {}#yiv7241900360 .yiv7241900360button td {}
GeoNet
Re: Failed to execute Generate CNGrid
reply from Kurtis Baron in Hydro - View the full discussion
Florence,
Kurt
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in Hydro by email or at GeoNet
Following Re: Failed to execute Generate CNGrid  in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
KurtisBaron
Florence,
The way we’ve made curve number grids is to make a lookup table that has a column for land use and a column for hydrologic soil group (A, B, C, or D), and CN. So, for a particular land use and a particular soil group you decide on a curve number based on the literature. When you generate a curve number grid the software looks at the land use grid, and looks at the soil group, and finds the curve number associated with those two variables in the lookup table and assigns the value it finds to the output CN grid for all cells in the grid extent.
You could therefore use the Identify tool to click on cells in your watershed and look at the values for all layers: land use grid, soil group grid, and the output CN grid, and see if the lookup table value for that land use and soil group matches the value in the output CN grid.
I noticed there’s some videos online when I searched for how to make a curve number grid.
Kurt
renzsamonte
Mr. Kurtis,
Thank you very much Mr. Kurtis for your clear explanation. I appreciate it very much. I attached here is the result of the CN generation. In the first figure, there is no CN grid in the Table of Contents but there is value when I click the "Identify" icon on the merged polygon of soil and land use. The figure below the attachment is the attribute table of the merged polygons showing the added column for CN. Is it alright if I manually encode the CN values wherever it is necessary?
Sir, I hope you don't mind if I share with you another concern and it is about the Longest Flowpath. I always get errors even if I followed carefully the procedures. Thank you very much.
Florence
On Thursday, 8 November 2018, 12:13:52 AM GMT+8, Kurtis Baron <[email protected]> wrote:
#yiv3292065671 * #yiv3292065671 a #yiv3292065671 body {font-family:Helvetica, Arial, sans-serif;}#yiv3292065671 #yiv3292065671 h1, #yiv3292065671 h2, #yiv3292065671 h3, #yiv3292065671 h4, #yiv3292065671 h5, #yiv3292065671 h6, #yiv3292065671 p, #yiv3292065671 hr {}#yiv3292065671 .yiv3292065671button td {}
GeoNet
Florence,
Kurt
KurtisBaron
It's OK to manually encode the CN values where necessary.
I don't know what the Longest flowpath error issue is.  Could be an issue with different versions of ArcGIS, Arc Hydro, Python, or something in the registry.  You might have to digitize your own flowpaths based on contours, but then you might get hydro ID messages or other errors.  Maybe someone from Esri's Arc Hydro group will chime in...
renzsamonte
Ok thank you very much.
On Friday, 9 November 2018, 12:19:08 AM GMT+8, Kurtis Baron <[email protected]> wrote:
#yiv4709837889 * #yiv4709837889 a #yiv4709837889 body {font-family:Helvetica, Arial, sans-serif;}#yiv4709837889 #yiv4709837889 h1, #yiv4709837889 h2, #yiv4709837889 h3, #yiv4709837889 h4, #yiv4709837889 h5, #yiv4709837889 h6, #yiv4709837889 p, #yiv4709837889 hr {}#yiv4709837889 .yiv4709837889button td {}
GeoNet
