Batch Watershed Delineation for Polygons
3143
09-07-2010 06:31 AM
LornaMurison
Hi everyone,
I'm trying to use the "Batch Watershed Delineation for Polygons" tool.  I have lakes, streams and a flow direction grid.  When I run the process, only the first lake gets a catchment delineated, but it is not assigned a HydroID.  All the other lakes are given a value of -1 in the "BatchDone" field.  There is a  post about this in the old forums which has not been answered:
[indent]
http://forums.esri.com/Thread.asp?c=93&f=995&t=258012&mc=3#msgid792857
[/indent]
Has anyone else encountered this problem?  Suggestions?
JulieCoco
Try changing the "BatchDone" field to "0" using the Field Calculator.  That should let you delineate the remaining watersheds from your points.  You should also complete the pre-processing steps before delineation.
