Convert from State Plane to Geographic WGS 1984
3470
08-30-2010 10:18 AM
JoseSanchez
Hi all
WE are currently using ArcLogistics online version 10.
When loading the zones layer in ArcLogistics created with State Plane Corrdinates, ArcLogistics requires to use the Geographic WGS 1984 coordinate system.
How can I convert my State Plane coordinates into Geographic WGS 1984 ones ?
Is there a way to use State Plane corrdinates in ArcLogistics?
Please advise
BertYagrich
Hi Jose, it sounds like you're trying to import a zones shapefile that is projected in the State Plane system?  If so, you'll need to use the Project Geoprocessing tool to convert the projection of your data. The actual projection used now is Web Mercator Auxiliary Sphere (WKID 102100) I believe.  This tool should be available in the toolbox for ArcMap or ArcCatalog.
If you don't have a copy of ArcGIS Desktop, I'm not sure how you might do this as ArcLogistics Online won't work well with State Plane projected files.
