Converting Layer to KML without Losing Attribute Table
15202
7
03-18-2016 08:43 AM
AzaN
Hi!
I need to convert Layer to KML (and vice versa). I use the tools embedded in ArcGIS toolbox to do that, but I loose the attribute table. Is there any way to convert without loosing the attributes?
Aza
AdrianWelsh
MVP Honored Contributor
Hi Aza,
Take a look at this blog post. I believe it will give helpful suggestions on how to perform this task:
Creating KML files with Attribute Data | Support Services Blog
AdrianWelsh
Hi Aza,
AzaN
Thank you very much, Adrian! It worked for me.
Azadeh
AzaN
Hi again,
How about the other way around: to convert KLM to layer. You have any idea how to keep the properties table in kml/kmz file as the attribute table in layer? When I use the related tool  in ArcGIS, it puts all the properties records in one field, just as the below pictures show.
Thanks again,
Azadeh
AdrianWelsh
Hi Aza,
Just to ask the obvious questions here, have you used the KML To Layer Tool in the Conversion Toolset?
KML To Layer—Help | ArcGIS for Desktop
AzaN
Yes Adrian. I dis use the KML to Layer tool in Conversion Toolset.
AdrianWelsh
Hmm, that seems to be a problem. There isn't an easy work around either.
Take a look at this thread:
https://community.esri.com/thread/115206#comment-432081
They used ArcGIS Explorer to make this happen and it appears to have worked.
Also, take a look at this:
arcgis 10.1 - Import KML attributes into the correct schema - Geographic Information Systems Stack E...
They used QGIS to make this happen.
AzaN
Yeah...it seems to be not very easy. I will try to use those tools. Thanks again for your help.
