Is SDK v200.x able to set minScale and max Scale?
921
10-09-2023 10:19 PM
trieunguyenaxon
Is there any way to config Map minScale and maxScale in ArcGIS SDK v200.x like v100.x
private var portal: AGSPortal?
private var map: AGSMap?
map.maxScale = MapConst.maxScale
map.minScale = MapConst.minScale
I can not find those APIs on the new SDK version v200.2
rolson_esri
Esri Alum
The types are no longer prefixed with "AGS" in the Swift version. It's a new API, not an exact port of the objective-c based API.
This works:
        var portal: Portal?
        var map: Map?
        map?.minScale = myMinScale
        map?.maxScale = myMaxScale
Here is a migration guide from 100.x to 200.x:
https://developers.arcgis.com/swift/reference/migrate-from-100-x-to-200-x/
Some blog posts you might be interested in:
https://developers.arcgis.com/swift/release-notes/prior-releases/release-notes-for-200-1/
https://www.esri.com/arcgis-blog/products/developers/announcements/whats-new-in-arcgis-maps-sdks-for...
rolson_esri
Esri Alum
This works:
        var portal: Portal?
        var map: Map?
