GeometryEditor.geometry is only triggering events on start and stop?
1759
12-29-2023 02:31 AM
dmc76
I have a .task( id: geometryEditor.geometry ) on my MapView (I have tried .onChange( of: ) and it behaves the same).  It triggers on geometryEditor.start() or .stop(), but it doesn't trigger on any interactive edits (adding/moving points, etc.)
I'm attempting to use the GeometryEditor as a convenient way to measure along a polyline or the area or edges of a polygon, so I really just need to update a Text() view after doing a few calculations on the current .geometry whenever it changes.  Am I missing something obvious? Is there something more I need to do than to add a .task or .onChange with the .geometry to observe?
Thanks!
-Dave
Ting
by Esri Regular Contributor
Thanks for asking this question! The geometry property is a "Streamed" property, which means its projected value (accessed with the dollar sign) is an asynchronous stream. In order to get updates from the stream, the new Swift Concurrency for-await-in syntax needs to be used.
Consider the snippet below. Whenever the geometry of the geometryEditor changes, the async stream will give an update.
If you aren't familiar with this topic, I recommend reading this blog (by me 😉) to get familiar with the gist of Swift Concurrency in ArcGIS Maps SDK.
Happy holidays!
import SwiftUI
import ArcGIS
struct ContentView: View {
    private class Model: ObservableObject {
        let map = Map(basemapStyle: .arcGISTopographic)
        let geometryEditor: GeometryEditor = {
            let editor = GeometryEditor()
            editor.tool = VertexTool()
            return editor
    @StateObject private var model = Model()
    var body: some View {
        MapView(map: model.map)
            .geometryEditor(model.geometryEditor)
            .task {
                for await geometry in model.geometryEditor.$geometry {
                    print("Geometry \(geometry?.extent) Changed")
            .onAppear {
                model.geometryEditor.start(withType: Polyline.self)
Ting
Happy holidays!
import SwiftUI
import ArcGIS
            return editor
            .task {
            .onAppear {
dmc76
I appreciate the help, the for/await was what I needed.  This is my first, and hopefully last Swift project.  I guess I'm just a dinosaur now and my 35 years of experience in the various flavors of C no longer translates to these hipster languages.
