Local Government GDB > Local Government SDE
4326
03-07-2014 10:32 AM
BrianO_keefe
Honored Contributor
My GIS co-worker and I are very interested in the Local Government Data Model, especially the Addressing section. We are putting a GIS foundation in place and would like to do it right. We have downloaded the Data Model and X-Ray and created the GeoDatabase. But we work in an SDE setup and would prefer to just port it over to SDE and keep on moving. However, I thought I remembered seeing that you had to keep it in GDB format for some reason or the other.
Can anyone let me know if the Local Government Data Model can be converted to SDE and used correctly from there?
LeonS
I'm running the current version of the model in SDE without any problems.  Early versions had just a few instances where field names were using reserved words in SQL Server, but those have been fixed.
Leon
BrianO_keefe
Honored Contributor
I'm just now importing from the XML workspace and getting some naming conflicts.
CV Domain : SignCode > SignCode_2
CV Domain : LandForm > LandForm_2
CV Domain : PoleType > PoleType_2
CV Domain : BulbType > BulbType_2
CV Domain > wHydrantManufacturer > wHydrantManufacturer_2
CV Domain > ServiceRequestType > ServiceRequestType_2
CV Domain > SignalType > SignalType_2
CV Domain > SpecialEventAreaType > SpecialEventAreaType_2
CV Domain > Direction > Direction_2
CV Domain > piAlertType > piAlertType_2
CV Domain > VideoFeedType > VideoFeedType_2
CV Domain > EmergencyFacility > EmergencyFacility_2
CV Domain > SpecialEventLineType > SpecialEventLineType_2
CV Domain > SpecialEventPointType > SpecialEventPointType_2
CV Domain > ParkingSpaceLocation > ParkingSpaceLocation_2
Any idea why these would show up in RED on a brand new dump? This is a brand new Local Government Database. I'm very confused.
BrianO_keefe
Honored Contributor
When I say "just now importing" I mean that I just deleted my original Local Gov DB (empty, no worries) and started a fresh update with the new XML Workspace...
GeorgiaPritchett
Deleting the Feature Data sets doesn't get rid of the domains from the SDE DB.  I have had that same set of warnings come up when I was working with my SDE db and it didn't cause problems.
Georgia
BrianO_keefe
Honored Contributor
Removed the domains and voila! Thank you so much!
