3 mile jurisdiction
806
04-26-2013 12:40 PM
JoshWhite
Honored Contributor
I've created a 3 mile buffer around the city for our city's extraterritorial jurisdiction but I've learned of a new statute concerning a small city that sprung up next to ours.  The statute reads that you can only go half the distance to the city instead of the full 3 miles.  So to simplify this, when somebody wants to do a subdivision, currently I would have to measure the distance to each of the cities to determine which one it is closest to.  If it is closer to mine than I have jurisdiction, if not, I don't have jurisdiction.  My question is, does anyone know of a way to map this?
Josh White, AICP
Principal Planner
City of Arkansas City
TrishRice
So you want to map the buffer around your city, trimmed on one side at the halfway point with the other city?  You could make a Thiessen polygon around your city and then Union it with your 3 mile buffer.  You need a layer of both cities' limits.  (This is assuming the limits are irregular and the halfway point is not already a convenient straight line.)
Now before you ask, I know Thiessen polygons are technically only for points.  But thanks to computers we can do this easily.  (Here's a topic when I was figuring out how to make polygons around my streets.)  Basically you turn all the city limits into a whole bunch of points at a convenient spacing, run thiessen polygons on those, and merge the sliver polygons back together into one big polygon for each city.
