Features randomly disappear in Scene Viewer
2494
5
06-06-2024 03:10 AM
Labels (2)
malte
I am having issues with the visualization of Feature Layers in Scene Viewer. I am using a local scene with EPSG 2169. When zooming in, features randomly disappear.
(view in My Videos)
The dev console shows the warning
[esri.views.3d.layers.graphics.Graphics3DCore] Graphic in layer 18fed015879-layer-12 has incompatible spatial reference and will not render
Does anyone know something about this issue?
dani
by Esri Contributor
Thanks for the information! I can't say for sure but based on your description, what you may be experiencing is a reduction in displayed features which can trigger if a lot of features are loaded and memory consumption gets too high. This depends on the device being used, among other factors.
However, we can let you know if we're able to repro this and it appears there's another cause/issue.
Dani
dani
by Esri Contributor
Would it be possible for you to provide a code snippet? That may help us understand what's going on.
Dani
malte
Hi dani,
I don't have any code for that, this is just a FeatureService opened in the built-in Scene Viewer in ArcGIS Portal 11.2
dani
by Esri Contributor
Would you be able to share a link to the feature layer you're using? That will help us try reproduce this behavior.
malte
Unfortunately, I can't share the link to this service due to sensitive information.
I looked a bit more into it and noticed two things. First, the issue does not appear with the same data, but published as a hosted feature layer instead of a feature layer that references an enterprise geodatabase. Also, if I apply a filter to the layer, the error appears a lot less frequently. It seems to me that the more features in total are requested, the more problems with drawing in the scene appear. As all our users only see subsets of the data, it's not a big issue for now.
dani
by Esri Contributor
Dani
