Unable to show related record on Web Scene
721
07-03-2024 11:55 PM
Labels (3)
ArchitSrivastava
Hi Community,
I am trying to achieve this new capability which ESRI released which allows to show "Related Records" on Web Scene by using Hosted Scene layers. However, the data on the related records shows blank.
Version : ArcGIS Enterprise 11.3
Workflow:
  • Publish Hosted Scene Layers
  • Add the Scene layer to Web Scene/Local Web Scene
  • Enable display "related record Display" on Pup-ups by following the below documentation:
  • Configure pop-ups in a scene—Portal for ArcGIS | Documentation for ArcGIS Enterprise
  • Select the feature and it will show the presence of related records. However, when you click on that it will not shows data from that related table.
  • Add the associated feature service to Web Map and enable display of related record. It will show all the data.
Can anyone share some thoughts or have experienced such issue before?
ArchitSrivastava
For reference purpose to whom so ever looks at this post in future to find a solution:
We logged a BUG by reaching out to ESRI:
  • BUG-000169197 : Unable to view related records when configuring the pop-up in Scene Viewer.
Workaround
  • Publish the data as a web scene from ArcGIS Pro.
  • Open the published web scene in ArcGIS Pro> add the related table to pop up and save.
Hope it helps!
ArchitSrivastava
Workaround
Hope it helps!
