Question on getting MouseEvent in QML
2039
04-21-2021 07:15 PM
Tkm_Knj
Hi.
I use Runtime version 100.8 and Qt 5.15.0 .
The code is almost the same, but I can't get MouseEvent.
Connections{
    target: mainMap
    //can't get
    function onMouseClicked() {
        var clickP = mainMap.screenToLocation(mouse.x, mouse.y)
        console.log(mouse.x)
    //can get
    onMouseClicked: {
On the side where I can get MouseEvent, I will get the following error.
QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
What should I do in this situation?
by Anonymous User
Not applicable
Hi there.
I'm also a tad confused with the new connection syntax in Qt 5.15, will take some time to get used to.
Here's a formulation that worked for me, try giving this a go.
MapView {
    anchors.fill: parent
    focus: true
    Map {
        // add the ArcGISStreets basemap to the map
        initBasemapStyle: Enums.BasemapStyleArcGISStreets
    Connections {
        target: mapView
        function onMouseClicked(mouseEvent) {
            console.log("x:", mouseEvent.x, "y:", mouseEvent.y)
by Anonymous User
Not applicable
Hi there.
MapView {
    focus: true
    Map {
    Connections {
        target: mapView
Tkm_Knj
Thanks!
It code is correct.
I can get MouseEvent.
