Error during the run Android application
13526
11
08-10-2022 03:53 AM
Labels (2)
tanerkoka
I want to run android  application with simple map using ArcGIS_Runtime_SDK_Qt_Windows_100_14_0 sdk. Im  using Qt Creator 7.0.2 Based on Qt 6.2.3 (MSVC 2019, 64 bit)  and Kits Qt 5.15.2   (Android  Clang Multi -Abi and  MinGW 64-bit ) . I installed the sdk from android studio. I use ndk separately from android studio (r17c) and last version of jdk-18.0.2.
When I create new simple project ArcGIS Runtime 100.14 Qt Quick QML app after nunning the project from Emulator. An error is received as below.
:-1: error: [C:\Users\h\Documents\build-map_4-Android_Qt_5_15_2_Clang_Multi_Abi-Release\android-build\libs/libs/RuntimeIndoors.jar] Error 1
How can I solve this  problem or  Is there a mistake in the sdk I use or. If , yes , which sdks are needed to use 100_14_0 sdk.
Here is a Tools and Android options pictures below.
Virtual DeviceVirtual Device
JamesBallard1
Oh yeah, I forgot to mention but I also get that ARM architecture too old issue as well. I think it's a bug with Qt Creator, but I'm not certain.
I see this issue looks related, but it's closed.
https://bugreports.qt.io/browse/QTCREATORBUG-25615
JamesBallard1
Hi @tanerkoka. As @HomeroOriaAguilera mentioned, the problem deploying RuntimeIndoors.jar was fixed at 100.14.1. See the release notes:
https://developers.arcgis.com/qt/release-notes/release-notes-for-100-14/
BUG-000149660 Android deployment problems on Windows with RuntimeIndoors.jar.
