Error during the run Android application
13481
11
08-10-2022 03:53 AM
Labels (2)
tanerkoka
I want to run android  application with simple map using ArcGIS_Runtime_SDK_Qt_Windows_100_14_0 sdk. Im  using Qt Creator 7.0.2 Based on Qt 6.2.3 (MSVC 2019, 64 bit)  and Kits Qt 5.15.2   (Android  Clang Multi -Abi and  MinGW 64-bit ) . I installed the sdk from android studio. I use ndk separately from android studio (r17c) and last version of jdk-18.0.2.
When I create new simple project ArcGIS Runtime 100.14 Qt Quick QML app after nunning the project from Emulator. An error is received as below.
:-1: error: [C:\Users\h\Documents\build-map_4-Android_Qt_5_15_2_Clang_Multi_Abi-Release\android-build\libs/libs/RuntimeIndoors.jar] Error 1
How can I solve this  problem or  Is there a mistake in the sdk I use or. If , yes , which sdks are needed to use 100_14_0 sdk.
Here is a Tools and Android options pictures below.
Virtual DeviceVirtual Device
2 Solutions
JamesBallard1
@tanerkoka you're nearly there! When you get the gray or white screen on Android, most of the time it is either missing SSL or an API key. I'd need to see your application output to know which one it is, but for now try to add SSL. You can do that in the project settings, seen here.
tanerkoka
Thank you for helping for Android part  JamesBallard1
Android problem was solved. Not being apiKey is causing problem .But the  problem continues with Desktop Qt 5.15.2 MinGW 64-bit.
Here is ıssues below picture.
HomeroOriaAguilera
Hi, if you want to continue using 100.14 version, you must see this post:
https://community.esri.com/t5/arcgis-runtime-sdk-for-qt-questions/app-doesn-t-start-at-full-deployme...
But, that error was fixed in 100.14.1 version released in June.
tanerkoka
Thank you for your refferal  HomeroOriaAguilera.
I tried to build with version 100.14.1, but during the build I got the following error. Can you help me? It will be an important step for me. Thank you.
java.lang.NoClassDefFoundError: Could not initialize class org.codehaus.groovy.vmplugin.v7.Java7
at org.codehaus.groovy.vmplugin.VMPluginFactory.<clinit>(VMPluginFactory.java:43)
at org.codehaus.groovy.reflection.GroovyClassValueFactory.<clinit>(GroovyClassValueFactory.java:35)
at org.codehaus.groovy.reflection.ClassInfo.<clinit>(ClassInfo.java:109)
at org.codehaus.groovy.reflection.ReflectionCache.getCachedClass(ReflectionCache.java:95)
at org.codehaus.groovy.reflection.ReflectionCache.<clinit>(ReflectionCache.java:39)
at org.codehaus.groovy.runtime.metaclass.MetaClassRegistryImpl.registerMethods(MetaClassRegistryImpl.java:209)
at org.codehaus.groovy.runtime.metaclass.MetaClassRegistryImpl.<init>(MetaClassRegistryImpl.java:107)
at org.codehaus.groovy.runtime.metaclass.MetaClassRegistryImpl.<init>(MetaClassRegistryImpl.java:85)
at groovy.lang.GroovySystem.<clinit>(GroovySystem.java:36)
at org.codehaus.groovy.runtime.InvokerHelper.<clinit>(InvokerHelper.java:86)
at groovy.lang.GroovyObjectSupport.getDefaultMetaClass(GroovyObjectSupport.java:59)
at groovy.lang.GroovyObjectSupport.<init>(GroovyObjectSupport.java:32)
at org.gradle.internal.extensibility.DefaultExtraPropertiesExtension.<init>(DefaultExtraPropertiesExtension.java:29)
at org.gradle.internal.extensibility.DefaultConvention.<init>(DefaultConvention.java:48)
at org.gradle.api.internal.plugins.DefaultConvention.<init>(DefaultConvention.java:28)
at org.gradle.internal.extensibility.ExtensibleDynamicObject.<init>(ExtensibleDynamicObject.java:60)
at org.gradle.internal.instantiation.MixInExtensibleDynamicObject.<init>(MixInExtensibleDynamicObject.java:34)
at org.gradle.initialization.DefaultSettings_Decorated.getAsDynamicObject(Unknown Source)
at org.gradle.initialization.SettingsFactory.createSettings(SettingsFactory.java:58)
at org.gradle.initialization.ScriptEvaluatingSettingsProcessor.process(ScriptEvaluatingSettingsProcessor.java:61)
at org.gradle.initialization.PropertiesLoadingSettingsProcessor.process(PropertiesLoadingSettingsProcessor.java:38)
at org.gradle.initialization.SettingsEvaluatedCallbackFiringSettingsProcessor.process(SettingsEvaluatedCallbackFiringSettingsProcessor.java:34)
at org.gradle.initialization.RootBuildCacheControllerSettingsProcessor.process(RootBuildCacheControllerSettingsProcessor.java:36)
at org.gradle.initialization.BuildOperationSettingsProcessor$2.call(BuildOperationSettingsProcessor.java:50)
at org.gradle.initialization.BuildOperationSettingsProcessor$2.call(BuildOperationSettingsProcessor.java:47)
at org.gradle.internal.operations.DefaultBuildOperationExecutor$CallableBuildOperationWorker.execute(DefaultBuildOperationExecutor.java:416)
at org.gradle.internal.operations.DefaultBuildOperationExecutor$CallableBuildOperationWorker.execute(DefaultBuildOperationExecutor.java:406)
at org.gradle.internal.operations.DefaultBuildOperationExecutor$1.execute(DefaultBuildOperationExecutor.java:165)
at org.gradle.internal.operations.DefaultBuildOperationExecutor.execute(DefaultBuildOperationExecutor.java:250)
at org.gradle.internal.operations.DefaultBuildOperationExecutor.execute(DefaultBuildOperationExecutor.java:158)
at org.gradle.internal.operations.DefaultBuildOperationExecutor.call(DefaultBuildOperationExecutor.java:102)
at org.gradle.internal.operations.DelegatingBuildOperationExecutor.call(DelegatingBuildOperationExecutor.java:36)
at org.gradle.initialization.BuildOperationSettingsProcessor.process(BuildOperationSettingsProcessor.java:47)
at org.gradle.initialization.DefaultSettingsLoader.findSettingsAndLoadIfAppropriate(DefaultSettingsLoader.java:104)
at org.gradle.initialization.DefaultSettingsLoader.findAndLoadSettings(DefaultSettingsLoader.java:45)
at org.gradle.initialization.SettingsAttachingSettingsLoader.findAndLoadSettings(SettingsAttachingSettingsLoader.java:35)
at org.gradle.internal.composite.CommandLineIncludedBuildSettingsLoader.findAndLoadSettings(CommandLineIncludedBuildSettingsLoader.java:34)
at org.gradle.internal.composite.ChildBuildRegisteringSettingsLoader.findAndLoadSettings(ChildBuildRegisteringSettingsLoader.java:47)
at org.gradle.internal.composite.CompositeBuildSettingsLoader.findAndLoadSettings(CompositeBuildSettingsLoader.java:35)
at org.gradle.initialization.DefaultSettingsPreparer.prepareSettings(DefaultSettingsPreparer.java:36)
at org.gradle.initialization.BuildOperatingFiringSettingsPreparer$LoadBuild.doLoadBuild(BuildOperatingFiringSettingsPreparer.java:59)
at org.gradle.initialization.BuildOperatingFiringSettingsPreparer$LoadBuild.run(BuildOperatingFiringSettingsPreparer.java:54)
at org.gradle.internal.operations.DefaultBuildOperationExecutor$RunnableBuildOperationWorker.execute(DefaultBuildOperationExecutor.java:402)
at org.gradle.internal.operations.DefaultBuildOperationExecutor$RunnableBuildOperationWorker.execute(DefaultBuildOperationExecutor.java:394)
at org.gradle.internal.operations.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:92)
at org.gradle.internal.operations.DelegatingBuildOperationExecutor.run(DelegatingBuildOperationExecutor.java:31)
at org.gradle.initialization.BuildOperatingFiringSettingsPreparer.prepareSettings(BuildOperatingFiringSettingsPreparer.java:42)
at org.gradle.initialization.DefaultGradleLauncher.prepareSettings(DefaultGradleLauncher.java:190)
at org.gradle.initialization.DefaultGradleLauncher.doClassicBuildStages(DefaultGradleLauncher.java:134)
at org.gradle.initialization.DefaultGradleLauncher.doBuildStages(DefaultGradleLauncher.java:126)
at org.gradle.initialization.DefaultGradleLauncher.executeTasks(DefaultGradleLauncher.java:106)
at org.gradle.internal.invocation.GradleBuildController$1.execute(GradleBuildController.java:60)
at org.gradle.internal.invocation.GradleBuildController$1.execute(GradleBuildController.java:57)
at org.gradle.internal.invocation.GradleBuildController$3.create(GradleBuildController.java:85)
at org.gradle.internal.invocation.GradleBuildController$3.create(GradleBuildController.java:78)
at org.gradle.internal.work.DefaultWorkerLeaseService.withLocks(DefaultWorkerLeaseService.java:189)
at org.gradle.internal.work.StopShieldingWorkerLeaseService.withLocks(StopShieldingWorkerLeaseService.java:40)
at org.gradle.internal.invocation.GradleBuildController.doBuild(GradleBuildController.java:78)
at org.gradle.internal.invocation.GradleBuildController.run(GradleBuildController.java:57)
at org.gradle.tooling.internal.provider.ExecuteBuildActionRunner.run(ExecuteBuildActionRunner.java:31)
at org.gradle.launcher.exec.ChainingBuildActionRunner.run(ChainingBuildActionRunner.java:35)
at org.gradle.launcher.exec.BuildOutcomeReportingBuildActionRunner.run(BuildOutcomeReportingBuildActionRunner.java:63)
at org.gradle.tooling.internal.provider.ValidatingBuildActionRunner.run(ValidatingBuildActionRunner.java:32)
at org.gradle.launcher.exec.BuildCompletionNotifyingBuildActionRunner.run(BuildCompletionNotifyingBuildActionRunner.java:39)
at org.gradle.launcher.exec.RunAsBuildOperationBuildActionRunner$3.call(RunAsBuildOperationBuildActionRunner.java:51)
at org.gradle.launcher.exec.RunAsBuildOperationBuildActionRunner$3.call(RunAsBuildOperationBuildActionRunner.java:45)
at org.gradle.launcher.exec.RunAsBuildOperationBuildActionRunner.run(RunAsBuildOperationBuildActionRunner.java:45)
at org.gradle.launcher.exec.InProcessBuildActionExecuter$1.transform(InProcessBuildActionExecuter.java:50)
at org.gradle.launcher.exec.InProcessBuildActionExecuter$1.transform(InProcessBuildActionExecuter.java:47)
at org.gradle.composite.internal.DefaultRootBuildState.run(DefaultRootBuildState.java:78)
at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:47)
at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:31)
at org.gradle.launcher.exec.BuildTreeScopeBuildActionExecuter.execute(BuildTreeScopeBuildActionExecuter.java:42)
at org.gradle.launcher.exec.BuildTreeScopeBuildActionExecuter.execute(BuildTreeScopeBuildActionExecuter.java:28)
at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:78)
at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:52)
at org.gradle.tooling.internal.provider.SubscribableBuildActionExecuter.execute(SubscribableBuildActionExecuter.java:59)
at org.gradle.tooling.internal.provider.SubscribableBuildActionExecuter.execute(SubscribableBuildActionExecuter.java:36)
at org.gradle.tooling.internal.provider.SessionScopeBuildActionExecuter.execute(SessionScopeBuildActionExecuter.java:68)
at org.gradle.tooling.internal.provider.SessionScopeBuildActionExecuter.execute(SessionScopeBuildActionExecuter.java:38)
at org.gradle.tooling.internal.provider.GradleThreadBuildActionExecuter.execute(GradleThreadBuildActionExecuter.java:37)
at org.gradle.tooling.internal.provider.GradleThreadBuildActionExecuter.execute(GradleThreadBuildActionExecuter.java:26)
at org.gradle.tooling.internal.provider.ParallelismConfigurationBuildActionExecuter.execute(ParallelismConfigurationBuildActionExecuter.java:43)
at org.gradle.tooling.internal.provider.ParallelismConfigurationBuildActionExecuter.execute(ParallelismConfigurationBuildActionExecuter.java:29)
at org.gradle.tooling.internal.provider.StartParamsValidatingActionExecuter.execute(StartParamsValidatingActionExecuter.java:60)
at org.gradle.tooling.internal.provider.StartParamsValidatingActionExecuter.execute(StartParamsValidatingActionExecuter.java:32)
at org.gradle.tooling.internal.provider.SessionFailureReportingActionExecuter.execute(SessionFailureReportingActionExecuter.java:55)
at org.gradle.tooling.internal.provider.SessionFailureReportingActionExecuter.execute(SessionFailureReportingActionExecuter.java:41)
at org.gradle.tooling.internal.provider.SetupLoggingActionExecuter.execute(SetupLoggingActionExecuter.java:48)
at org.gradle.tooling.internal.provider.SetupLoggingActionExecuter.execute(SetupLoggingActionExecuter.java:32)
at org.gradle.launcher.daemon.server.exec.ExecuteBuild.doBuild(ExecuteBuild.java:68)
at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:37)
at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:104)
at org.gradle.launcher.daemon.server.exec.WatchForDisconnection.execute(WatchForDisconnection.java:39)
at org.gradle.launcher.daemon.server.exec.ResetDeprecationLogger.execute(ResetDeprecationLogger.java:27)
at org.gradle.launcher.daemon.server.exec.RequestStopIfSingleUsedDaemon.execute(RequestStopIfSingleUsedDaemon.java:35)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.create(ForwardClientInput.java:78)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.create(ForwardClientInput.java:75)
at org.gradle.util.Swapper.swap(Swapper.java:38)
at org.gradle.launcher.daemon.server.exec.ForwardClientInput.execute(ForwardClientInput.java:75)
at org.gradle.launcher.daemon.server.exec.LogAndCheckHealth.execute(LogAndCheckHealth.java:55)
at org.gradle.launcher.daemon.server.exec.LogToClient.doBuild(LogToClient.java:63)
at org.gradle.launcher.daemon.server.exec.EstablishBuildEnvironment.doBuild(EstablishBuildEnvironment.java:82)
at org.gradle.launcher.daemon.server.exec.StartBuildOrRespondWithBusy$1.run(StartBuildOrRespondWithBusy.java:52)
at org.gradle.launcher.daemon.server.DaemonStateCoordinator$1.run(DaemonStateCoordinator.java:297)
at org.gradle.internal.concurrent.ExecutorPolicy$CatchAndRecordFailures.onExecute(ExecutorPolicy.java:64)
at org.gradle.internal.concurrent.ManagedExecutorImpl$1.run(ManagedExecutorImpl.java:48)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at org.gradle.internal.concurrent.ThreadFactoryImpl$ManagedThreadRunnable.run(ThreadFactoryImpl.java:56)
at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: java.lang.ExceptionInInitializerError: Exception org.codehaus.groovy.GroovyBugError [in thread "Daemon worker"]
at org.codehaus.groovy.vmplugin.v7.Java7.<clinit>(Java7.java:45)
at java.base/jdk.internal.misc.Unsafe.ensureClassInitialized0(Native Method)
at java.base/jdk.internal.misc.Unsafe.ensureClassInitialized(Unsafe.java:1160)
at java.base/jdk.internal.reflect.MethodHandleAccessorFactory.ensureClassInitialized(MethodHandleAccessorFactory.java:300)
at java.base/jdk.internal.reflect.MethodHandleAccessorFactory.newConstructorAccessor(MethodHandleAccessorFactory.java:103)
at java.base/jdk.internal.reflect.ReflectionFactory.newConstructorAccessor(ReflectionFactory.java:236)
at java.base/java.lang.reflect.Constructor.acquireConstructorAccessor(Constructor.java:546)
at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:496)
at java.base/java.lang.reflect.ReflectAccess.newInstance(ReflectAccess.java:128)
at java.base/jdk.internal.reflect.ReflectionFactory.newInstance(ReflectionFactory.java:341)
at java.base/java.lang.Class.newInstance(Class.java:677)
at org.codehaus.groovy.vmplugin.VMPluginFactory.createPlugin(VMPluginFactory.java:57)
at org.codehaus.groovy.vmplugin.VMPluginFactory.<clinit>(VMPluginFactory.java:39)
... 129 more
FAILURE: Build failed with an exception.
* What went wrong:
Could not initialize class org.codehaus.groovy.reflection.ReflectionCache
> Exception java.lang.NoClassDefFoundError: Could not initialize class org.codehaus.groovy.vmplugin.v7.Java7 [in thread "Daemon worker"]
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
* Get more help at https://help.gradle.org
BUİLD FAILED in 4s
Building the android package failed!
-- For more information, run this command with --verbose.
14:25:04: The process "C:\Qt\5.15.2\android\bin\androiddeployqt.exe" exited with code 14.
Error while building/deploying project map (kit: Android Qt 5.15.2 Clang Multi-Abi)
When executing step "Build Android APK"
14:25:04: Elapsed time: 02:33.
Here is also errors picture below.
Here is also config Android options picture below.
JamesBallard1
@tanerkoka we've also hit issues like this, specifically with gradle. Qt/Qt Creator controls which version of gradle is used, and different versions can impact which version of Java you need.
One thing I noticed is that your NDK version specified doesn't meet our minimum requirement.
https://developers.arcgis.com/qt/reference/system-requirements/#deploying-apps-to-android
21b minimum
Other than that I would review the version of Java you're using. Review Qt's requirements here:
https://doc.qt.io/qt-5/android-getting-started.html
Note: If you are using the SDK Tools 26.x or below, the JDK 8 is required. Versions higher than 8 might cause issues for the Android SDK tools.
And:
Note:JDK 11 or earlier must be used when using Qt for Android.
Hopefully this will get you on the right track.
tanerkoka
Thank you for helping  HomeroOriaAguilera.
 As you said , I used jdk-11 as JDK  also I used ndk-r21e as NDK. Android package built successfully , .apk file is successfully istalled on the device , but it opens to an gray usage instead of the map 😞 . Can you help me again ?
Here is screen picture below.
Here is also issues picture and main.cpp file picture below.
Here is also Androis Device Config picture below.
Here is Compile output below:
14:18:31: Running steps for project map_1...
14:18:31: Starting: "C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe" clean -j8
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.Arm64-v8a clean
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.Armeabi-v7a clean
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.X86 clean
rmdir /s /q C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build
make[1]: Entering directory 'C:/Users/h-/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug'
del arm64-v8a\qrc_qml.cpp arm64-v8a\qrc_Resources.cpp
make[1]: Entering directory 'C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug'
del armeabi-v7a\qrc_qml.cpp armeabi-v7a\qrc_Resources.cpp
del arm64-v8a\moc_predefs.h
del x86\qrc_qml.cpp x86\qrc_Resources.cpp
del armeabi-v7a\moc_predefs.h
Sistem belirtilen dosyay bulamyor.
make: *** [Makefile:523: android-build-distclean] Error 2
make: *** Waiting for unfinished jobs....
del x86\moc_predefs.h
del arm64-v8a\main.obj arm64-v8a\qrc_qml.obj arm64-v8a\qrc_Resources.obj
del armeabi-v7a\main.obj armeabi-v7a\qrc_qml.obj armeabi-v7a\qrc_Resources.obj
del x86\main.obj x86\qrc_qml.obj x86\qrc_Resources.obj
del *~ core *.core
del *~ core *.core
del *~ core *.core
make[1]: Leaving directory 'C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug'
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\arm64-v8a\qrc_qml.cpp
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\armeabi-v7a\qrc_qml.cpp
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\arm64-v8a\moc_predefs.h
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\x86\qrc_qml.cpp
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\armeabi-v7a\moc_predefs.h
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\x86\moc_predefs.h
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\arm64-v8a\main.obj
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\armeabi-v7a\main.obj
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\x86\main.obj
Could Not Find C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\*~
14:18:36: The process "C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe" exited with code 2.
14:18:36: Starting: "C:\Qt\5.15.2\android\bin\qmake.exe" C:\Users\h-tkoka\Documents\map_1\map_1.pro -spec android-clang "CONFIG+=debug" "CONFIG+=qml_debug" ANDROID_ABIS="armeabi-v7a"
Project MESSAGE: ArcGIS Runtime for Android (arm64-v8a)
Project MESSAGE: Version 100.14.1
Project MESSAGE: ArcGIS Runtime for Android (armeabi-v7a)
Project MESSAGE: ArcGIS Runtime for Android (x86)
14:18:39: The process "C:\Qt\5.15.2\android\bin\qmake.exe" exited normally.
14:18:39: Starting: "C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe" -f C:/Users/h-tkoka/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/Makefile qmake_all
make: Nothing to be done for 'qmake_all'.
14:18:40: The process "C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe" exited normally.
14:18:40: Starting: "C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe" -j8
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.Arm64-v8a all
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.Armeabi-v7a all
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.X86 all
if not exist C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs mkdir C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs & if not exist C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs exit 1
make[1]: Entering directory 'C:/Users/h-tkoka/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug'
if not exist C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs mkdir C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs & if not exist C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs exit 1
copy /y "C:\Program Files (x86)\ArcGIS SDKs\Qt100.14.1\sdk\android\jar\RuntimeIndoors.jar" C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs
1 file(s) copied.
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target armv7a-linux-androideabi21 -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -marm -O0 -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Iarmeabi-v7a -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o armeabi-v7a\main.obj ..\map_1\main.cpp
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target aarch64-linux-android21 -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Iarm64-v8a -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o arm64-v8a\main.obj ..\map_1\main.cpp
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target i686-linux-android21 -mstackrealign -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Ix86 -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o x86\main.obj ..\map_1\main.cpp
C:\Qt\5.15.2\android\bin\rcc.exe -name qml ..\map_1\qml\qml.qrc -o armeabi-v7a\qrc_qml.cpp
C:\Qt\5.15.2\android\bin\rcc.exe -name qml ..\map_1\qml\qml.qrc -o x86\qrc_qml.cpp
1 file(s) copied.
C:\Qt\5.15.2\android\bin\rcc.exe -name qml ..\map_1\qml\qml.qrc -o arm64-v8a\qrc_qml.cpp
1 file(s) copied.
1 file(s) copied.
C:\Qt\5.15.2\android\bin\rcc.exe -name Resources ..\map_1\Resources\Resources.qrc -o x86\qrc_Resources.cpp
C:\Qt\5.15.2\android\bin\rcc.exe -name Resources ..\map_1\Resources\Resources.qrc -o armeabi-v7a\qrc_Resources.cpp
C:\Qt\5.15.2\android\bin\rcc.exe -name Resources ..\map_1\Resources\Resources.qrc -o arm64-v8a\qrc_Resources.cpp
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target i686-linux-android21 -mstackrealign -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Ix86 -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o x86\qrc_qml.obj x86\qrc_qml.cpp
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target armv7a-linux-androideabi21 -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -marm -O0 -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Iarmeabi-v7a -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o armeabi-v7a\qrc_qml.obj armeabi-v7a\qrc_qml.cpp
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target aarch64-linux-android21 -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Iarm64-v8a -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o arm64-v8a\qrc_qml.obj arm64-v8a\qrc_qml.cpp
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target armv7a-linux-androideabi21 -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -marm -O0 -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Iarmeabi-v7a -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o armeabi-v7a\qrc_Resources.obj armeabi-v7a\qrc_Resources.cpp
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target i686-linux-android21 -mstackrealign -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Ix86 -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o x86\qrc_Resources.obj x86\qrc_Resources.cpp
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -c -target aarch64-linux-android21 -fno-limit-debug-info -fPIC -fstack-protector-strong -DANDROID -g -std=gnu++1y -Wall -W -D_REENTRANT -fPIC -DARCGIS_RUNTIME_IMPORT_PATH_2="\"C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml\"" -DARCGIS_RUNTIME_IMPORT_PATH="C:/ProgramData/EsriRuntimeQt/Qt100.14/android/qml" -DQT_QML_DEBUG -DQT_QUICK_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_QMLMODELS_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_POSITIONING_LIB -DQT_SENSORS_LIB -DQT_BLUETOOTH_LIB -DQT_ANDROIDEXTRAS_LIB -DQT_CORE_LIB -I..\map_1 -I. -I..\map_1\Android -I..\..\..\..\Qt\5.15.2\android\include -I..\..\..\..\Qt\5.15.2\android\include\QtQuick -I..\..\..\..\Qt\5.15.2\android\include\QtMultimedia -I..\..\..\..\Qt\5.15.2\android\include\QtGui -I..\..\..\..\Qt\5.15.2\android\include\QtQmlModels -I..\..\..\..\Qt\5.15.2\android\include\QtQml -I..\..\..\..\Qt\5.15.2\android\include\QtNetwork -I..\..\..\..\Qt\5.15.2\android\include\QtPositioning -I..\..\..\..\Qt\5.15.2\android\include\QtSensors -I..\..\..\..\Qt\5.15.2\android\include\QtBluetooth -I..\..\..\..\Qt\5.15.2\android\include\QtAndroidExtras -I..\..\..\..\Qt\5.15.2\android\include\QtCore -Iarm64-v8a -I..\..\..\..\Qt\5.15.2\android\mkspecs\android-clang -o arm64-v8a\qrc_Resources.obj arm64-v8a\qrc_Resources.cpp
copy /y "C:/Program Files (x86)/ArcGIS SDKs/Qt100.14.1\sdk\android\lib\libruntimecore_armeabi-v7a.so" "C:/Users/hDocuments/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\libruntimecore_armeabi-v7a.so"
copy /y "C:/Program Files (x86)/ArcGIS SDKs/Qt100.14.1\sdk\android\lib\libruntimecore_x86.so" "C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\libruntimecore_x86.so"
copy /y "C:/Program Files (x86)/ArcGIS SDKs/Qt100.14.1\sdk\android\lib\libruntimecore_arm64-v8a.so" "C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\libruntimecore_arm64-v8a.so"
1 file(s) copied.
copy /y "C:/Program Files (x86)/ArcGIS SDKs/Qt100.14.1\sdk\android\lib\libEsriCommonQt_armeabi-v7a.so" "C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\libEsriCommonQt_armeabi-v7a.so"
1 file(s) copied.
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -target armv7a-linux-androideabi21 -fno-limit-debug-info -Wl,-soname,libmap_1_armeabi-v7a.so -Wl,-rpath-link=C:/Qt/5.15.2/android/lib -Wl,--build-id=sha1 -Wl,--no-undefined -Wl,-z,noexecstack -shared -o libmap_1_armeabi-v7a.so armeabi-v7a\main.obj armeabi-v7a\qrc_qml.obj armeabi-v7a\qrc_Resources.obj -LC:/Users/h-tkoka/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug -lEsriCommonQt_armeabi-v7a C:/Qt/5.15.2/android/lib/libQt5Quick_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5Multimedia_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5Gui_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5QmlModels_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5Qml_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5Network_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5Positioning_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5Sensors_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5Bluetooth_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5AndroidExtras_armeabi-v7a.so C:/Qt/5.15.2/android/lib/libQt5Core_armeabi-v7a.so -lGLESv2 -llog -lz -lm -ldl -lc
1 file(s) copied.
copy /y "C:/Program Files (x86)/ArcGIS SDKs/Qt100.14.1\sdk\android\lib\libEsriCommonQt_x86.so" "C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\libEsriCommonQt_x86.so"
1 file(s) copied.
copy /y "C:/Program Files (x86)/ArcGIS SDKs/Qt100.14.1\sdk\android\lib\libEsriCommonQt_arm64-v8a.so" "C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\libEsriCommonQt_arm64-v8a.so"
1 file(s) copied.
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -target aarch64-linux-android21 -fno-limit-debug-info -Wl,-soname,libmap_1_arm64-v8a.so -Wl,-rpath-link=C:/Qt/5.15.2/android/lib -Wl,--build-id=sha1 -Wl,--no-undefined -Wl,-z,noexecstack -shared -o libmap_1_arm64-v8a.so arm64-v8a\main.obj arm64-v8a\qrc_qml.obj arm64-v8a\qrc_Resources.obj -LC:/Users/h-tkoka/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug -lEsriCommonQt_arm64-v8a C:/Qt/5.15.2/android/lib/libQt5Quick_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5Multimedia_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5Gui_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5QmlModels_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5Qml_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5Network_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5Positioning_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5Sensors_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5Bluetooth_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5AndroidExtras_arm64-v8a.so C:/Qt/5.15.2/android/lib/libQt5Core_arm64-v8a.so -lGLESv2 -llog -lz -lm -ldl -lc
1 file(s) copied.
C:\Android\android-ndk-r21e/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++ -target i686-linux-android21 -mstackrealign -fno-limit-debug-info -Wl,-soname,libmap_1_x86.so -Wl,-rpath-link=C:/Qt/5.15.2/android/lib -Wl,--build-id=sha1 -Wl,--no-undefined -Wl,-z,noexecstack -shared -o libmap_1_x86.so x86\main.obj x86\qrc_qml.obj x86\qrc_Resources.obj -LC:/Users/h-tkoka/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug -lEsriCommonQt_x86 C:/Qt/5.15.2/android/lib/libQt5Quick_x86.so C:/Qt/5.15.2/android/lib/libQt5Multimedia_x86.so C:/Qt/5.15.2/android/lib/libQt5Gui_x86.so C:/Qt/5.15.2/android/lib/libQt5QmlModels_x86.so C:/Qt/5.15.2/android/lib/libQt5Qml_x86.so C:/Qt/5.15.2/android/lib/libQt5Network_x86.so C:/Qt/5.15.2/android/lib/libQt5Positioning_x86.so C:/Qt/5.15.2/android/lib/libQt5Sensors_x86.so C:/Qt/5.15.2/android/lib/libQt5Bluetooth_x86.so C:/Qt/5.15.2/android/lib/libQt5AndroidExtras_x86.so C:/Qt/5.15.2/android/lib/libQt5Core_x86.so -lGLESv2 -llog -lz -lm -ldl -lc
14:18:58: The process "C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe" exited normally.
14:18:58: Removing directory C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build/libs
14:18:58: Starting: "C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe" "INSTALL_ROOT=C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build" install && cd C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug && C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe "INSTALL_ROOT=C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build" install
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.Arm64-v8a install
if not exist C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs mkdir C:\Users\h-\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs & if not exist C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs exit 1
copy /y "C:\Program Files (x86)\ArcGIS SDKs\Qt100.14.1\sdk\android\jar\RuntimeIndoors.jar" C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs
1 file(s) copied.
C:\Qt\5.15.2\android\bin\qmake.exe -install qinstall -exe libmap_1_arm64-v8a.so C:\Users\h\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs\arm64-v8a\libmap_1_arm64-v8a.so
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.Armeabi-v7a install
C:\Qt\5.15.2\android\bin\qmake.exe -install qinstall -exe libmap_1_armeabi-v7a.so C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs\armeabi-v7a\libmap_1_armeabi-v7a.so
C:/Android/android-ndk-r21e/prebuilt/windows-x86_64/bin/make -f Makefile.X86 install
C:\Qt\5.15.2\android\bin\qmake.exe -install qinstall -exe libmap_1_x86.so C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs\x86\libmap_1_x86.so
C:\Qt\5.15.2\android\bin\qmake.exe -install qinstall -exe libmap_1_arm64-v8a.so C:\Users\h-tkoka\Documents\build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build\libs\arm64-v8a\libmap_1_arm64-v8a.so
14:19:05: The process "C:\Android\android-ndk-r21e\prebuilt\windows-x86_64\bin\make.exe" exited normally.
14:19:05: Starting: "C:\Qt\5.15.2\android\bin\androiddeployqt.exe" --input C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/android-map_1-deployment-settings.json --output C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/android-build --android-platform android-27 --jdk "C:/Program Files/Java/jdk-11" --gradle
Generating Android Package
Input file: C:/Users/h-tkoka/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/android-map_1-deployment-settings.json
Output directory: C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/android-build/
Application binary: map_1
Android build platform: android-27
Install to device: No
-- Skipping C:/Qt/5.15.2/android/plugins/iconengines/libplugins_iconengines_qsvgicon_arm64-v8a.so. It has unmet dependencies: lib/libQt5Svg_arm64-v8a.so,lib/libQt5Widgets_arm64-v8a.so.
-- Skipping C:/Qt/5.15.2/android/plugins/imageformats/libplugins_imageformats_qsvg_arm64-v8a.so. It has unmet dependencies: lib/libQt5Svg_arm64-v8a.so,lib/libQt5Widgets_arm64-v8a.so.
-- Skipping C:/Qt/5.15.2/android/plugins/position/libplugins_position_qtposition_serialnmea_arm64-v8a.so. It has unmet dependencies: lib/libQt5SerialPort_arm64-v8a.so.
-- Skipping C:/Qt/5.15.2/android/plugins/iconengines/libplugins_iconengines_qsvgicon_armeabi-v7a.so. It has unmet dependencies: lib/libQt5Svg_armeabi-v7a.so,lib/libQt5Widgets_armeabi-v7a.so.
-- Skipping C:/Qt/5.15.2/android/plugins/imageformats/libplugins_imageformats_qsvg_armeabi-v7a.so. It has unmet dependencies: lib/libQt5Svg_armeabi-v7a.so,lib/libQt5Widgets_armeabi-v7a.so.
-- Skipping C:/Qt/5.15.2/android/plugins/position/libplugins_position_qtposition_serialnmea_armeabi-v7a.so. It has unmet dependencies: lib/libQt5SerialPort_armeabi-v7a.so.
-- Skipping C:/Qt/5.15.2/android/plugins/iconengines/libplugins_iconengines_qsvgicon_x86.so. It has unmet dependencies: lib/libQt5Svg_x86.so,lib/libQt5Widgets_x86.so.
-- Skipping C:/Qt/5.15.2/android/plugins/imageformats/libplugins_imageformats_qsvg_x86.so. It has unmet dependencies: lib/libQt5Svg_x86.so,lib/libQt5Widgets_x86.so.
-- Skipping C:/Qt/5.15.2/android/plugins/position/libplugins_position_qtposition_serialnmea_x86.so. It has unmet dependencies: lib/libQt5SerialPort_x86.so.
Starting a Gradle Daemon, 3 incompatible and 1 stopped Daemons could not be reused, use --status for details
Warning: Mapping new ns http://schemas.android.com/repository/android/common/02 to old ns http://schemas.android.com/repository/android/common/01
Warning: Mapping new ns http://schemas.android.com/repository/android/generic/02 to old ns http://schemas.android.com/repository/android/generic/01
Warning: Mapping new ns http://schemas.android.com/sdk/android/repo/addon2/02 to old ns http://schemas.android.com/sdk/android/repo/addon2/01
Warning: Mapping new ns http://schemas.android.com/sdk/android/repo/addon2/03 to old ns http://schemas.android.com/sdk/android/repo/addon2/01
Warning: Mapping new ns http://schemas.android.com/sdk/android/repo/repository2/02 to old ns http://schemas.android.com/sdk/android/repo/repository2/01
Warning: Mapping new ns http://schemas.android.com/sdk/android/repo/repository2/03 to old ns http://schemas.android.com/sdk/android/repo/repository2/01
Warning: Mapping new ns http://schemas.android.com/sdk/android/repo/sys-img2/03 to old ns http://schemas.android.com/sdk/android/repo/sys-img2/01
Warning: Mapping new ns http://schemas.android.com/sdk/android/repo/sys-img2/02 to old ns http://schemas.android.com/sdk/android/repo/sys-img2/01
Warning: unexpected element (uri:"", local:"base-extension"). Expected elements are <{}codename>,<{}layoutlib>,<{}api-level>
> Task :preBuild UP-TO-DATE
> Task :preDebugBuild UP-TO-DATE
> Task :compileDebugAidl
> Task :compileDebugRenderscript NO-SOURCE
> Task :generateDebugBuildConfig
> Task :mainApkListPersistenceDebug
> Task :generateDebugResValues
> Task :generateDebugResources
> Task :createDebugCompatibleScreenManifests
> Task :extractDeepLinksDebug
> Task :processDebugManifest
> Task :mergeDebugShaders
> Task :compileDebugShaders
> Task :generateDebugAssets
> Task :mergeDebugAssets
> Task :processDebugJavaRes NO-SOURCE
> Task :mergeDebugResources
> Task :processDebugResources
> Task :checkDebugDuplicateClasses
> Task :javaPreCompileDebug
> Task :compileDebugJavaWithJavac
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
> Task :compileDebugSources
> Task :dexBuilderDebug
> Task :desugarDebugFileDependencies
> Task :mergeDebugJniLibFolders
> Task :mergeDebugJavaResource
> Task :validateSigningDebug
> Task :mergeExtDexDebug
> Task :mergeLibDexDebug
> Task :mergeProjectDexDebug
> Task :mergeDebugNativeLibs
> Task :stripDebugDebugSymbols
> Task :packageDebug
> Task :assembleDebug
BUİLD SUCCESSFUL in 2m 36s
26 actionable tasks: 26 executed
Android package built successfully in 293.599 ms.
-- File: C:/Users/h/Documents/build-map_1-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/android-build//build/outputs/apk/debug/android-build-debug.apk
14:23:59: The process "C:\Qt\5.15.2\android\bin\androiddeployqt.exe" exited normally.
14:23:59: Elapsed time: 05:28.
JamesBallard1
tanerkoka
JamesBallard1
@tanerkoka we do not support the MinGW kit on Windows. You must use the Visual Studio 2019 kit with the Runtime SDK for Qt on Windows. This is the reason you are seeing these build errors.
tanerkoka
After uninstalling the MinGW kits, which one should I choose from the Maintenance Tool instead? I was in a following as in the picure MSVC 2019 select.Is there an example of how to do it?
JamesBallard1
It is the MSVC 2019 64-bit option.
