Does FeatureRequestModeOnInteractionCache only cache features while they're within the current extent?
2070
11-23-2016 05:19 PM
JonathonGrivas
Hello again, I'm still working in v100.0 and I've decided to test the feature table caching. The default mode (OnInteractionCache) seems to cache features that are already on screen, and the only time it doesn't send out a request is if I zoom in on a point that's already on screen.  If I pan back and forth within the same small area, it sends requests every time and it receives the exact same responses every time. I thought the cached features would persist in memory  even if you change extents and come back, is that wrong?
LucasDanzinger
Esri Frequent Contributor
Jonathon-
This seems like a bug. I can see the same behavior in the sample. Can you please log a bug with Esri Support so they can get it in the system?
Luke
