ArcGisRuntime V100: example not working 'GraphicsOverlayDictionaryRenderer_3D'
1786
11-25-2016 06:02 AM
NorbertThoden
The following example is not working, that means, the globe is visible, but just the BackgroundGrid 😞
GitHub example:
arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_CppSamples/DisplayInformation/GraphicsOverlayDictionaryRenderer_3D
Can esri fix their example, please?
(Keep in mind, unix systems are case sensitive....)
Thx
EricBader
Honored Contributor
Hello!
Check to make sure you can access the elevation and imagery basemap services from your computer where your sample is running. Does your network require a proxy out to access external services?
NorbertThoden
Hi! Eric!
Yes you are right, is missed added the proxy snippet 😞
Thank you.
(And sorry for the stupid question..)
NorbertThoden
Hi!
I have another problem.
Luke Smallwood gave access to the required xml file which is unfortunately NOT included in the github.
Mil2525DMessages.xml (md5: 20d2386c92976eb43007e38f31d63795)
Using this the example crashed:
Program received signal SIGABRT, Aborted.
0x00007ffff4d6dcc9 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
56 ../nptl/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) bt
#0 0x00007ffff4d6dcc9 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
#1 0x00007ffff4d710d8 in __GI_abort () at abort.c:89
#2 0x00007ffff4d66b86 in __assert_fail_base (fmt=0x7ffff4eb7830 "%s%s%s:%u: %s%sAssertion `%s' failed.\n%n",
assertion=assertion@entry=0x7ffff09cda45 "(-(e)) != 3 || !robust", file=file@entry=0x7ffff09cda28 "../nptl/pthread_mutex_lock.c", line=line@entry=350,
function=function@entry=0x7ffff09cdb40 <__PRETTY_FUNCTION__.8671> "__pthread_mutex_lock_full") at assert.c:92
#3 0x00007ffff4d66c32 in __GI___assert_fail (assertion=assertion@entry=0x7ffff09cda45 "(-(e)) != 3 || !robust",
function=function@entry=0x7ffff09cdb40 <__PRETTY_FUNCTION__.8671> "__pthread_mutex_lock_full") at assert.c:101
#4 0x00007ffff09c0ce1 in __pthread_mutex_lock_full (mutex=0xc327d8) at ../nptl/pthread_mutex_lock.c:350
#5 0x00007ffff37ca3c6 in std::__1::mutex::lock() () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#6 0x00007ffff1d43030 in ?? () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#7 0x00007ffff1f8dbc8 in ?? () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#8 0x00007ffff1b39738 in ?? () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#9 0x00007ffff1f74dcf in ?? () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#10 0x00007ffff1f832e0 in ?? () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#11 0x00007ffff1f8631f in ?? () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#12 0x00007ffff1a612c0 in ?? () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#13 0x00007ffff1a60b63 in RT_Vector_add () from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libruntimecore.so
#14 0x00007ffff78f91c3 in ESRI::RuntimeCore::QRTVector::add(ESRI::RuntimeCore::QRTElement*) const ()
from /home/quartzfinal/arcgis/runtime_sdk/qt100.0/sdk/linux/x64/lib/libEsriCommonQt.so
#15 0x00007ffff7671a09 in QRTImpl::List<QRTImpl::GraphicImpl>::append(std::shared_ptr<QRTImpl::GraphicImpl> const&) ()
#16 0x00007ffff770ac93 in QRTImpl::GraphicListImpl::append(std::shared_ptr<QRTImpl::GraphicImpl> const&) ()
#17 0x0000000000496bb5 in Esri::ArcGISRuntime::GraphicListModel::append(Esri::ArcGISRuntime::Graphic*) ()
#18 0x000000000047293b in GraphicsOverlayDictionaryRenderer_3D::createGraphic (this=0x844780, rawAttributes=...)
at ../GraphicsOverlayDictionaryRenderer_3D_Symbology/GraphicsOverlayDictionaryRenderer_3D.cpp:174
#19 0x0000000000472368 in GraphicsOverlayDictionaryRenderer_3D::parseXmlFile (this=0x844780)
NorbertThoden
As recommended i "moved" this issue to GitHub:
https://github.com/Esri/arcgis-runtime-samples-qt/issues/367
