Can't setting SpatialReference and get Latitude/Longitude QML
1518
04-27-2021 07:15 PM
KanjaSousuke
I use Esri.ArcGISRuntime 100.9 and Qt5.15.0.
I want to get Latitude and Longitude, but can't get.
My code is
ApplicationWindow {
    width: 800
    height: 600
    title: "MapTest2"
    property int count: 0
    // add a mapView component
    MapView {
        anchors.fill: parent
        // set focus to enable keyboard navigation
        focus: true
        // add a map to the mapview
        Map {
            // add the BasemapTopographic basemap to the map
            BasemapTopographic {}
        MultipointBuilder{
            spatialReference: SpatialReference {
                    wkid: 6668
        onMouseClicked: {
            console.log(mouse.mapPoint.x)
            console.log(clickPoint.points.addPoint(screenToLocation(mouse.x,mouse.y)))
            console.log(clickPoint.points.point(count).x)
            count++
This code display the following statement in the console.
qml: 11170910.901105005
qml: -1
qrc:/qml/main.qml:50: TypeError: Cannot read property 'x' of null
I think this problem is [SpatialReference].
Because, when I did the following and got no errors or anything.
        MultipointBuilder{
            spatialReference: mapView.spatialReference
But, this code can't get Latitude/Longitude in wkid:6668
Is there any way we can solve this problem?
LucasDanzinger
Esri Frequent Contributor
I believe the issue might be that your points/coordinates coming from the mapview click event is coming in 3857 (web mercator), and then you are trying to add these points to a builder that is using 6668.
My suggestion is to use GeometryEngine.project to take the 3857-based points and project them into 6668 before you call addPoint on the builder. That way, you are adding the points to the builder in the correct spatial reference
https://developers.arcgis.com/qt/qml/api-reference/qml-esri-arcgisruntime-geometryengine.html#projec...
LucasDanzinger
KanjaSousuke
Thanks!
I can get.
