application crash in 64 bit mode
2525
04-25-2013 10:15 PM
RalfWiesner
application crash in 64 bit mode while loading map package
EsriRuntimeQt::ArcGISLocalDynamicMapServiceLayer dynamicLayer("../../samples/data/mpks/USCitiesStates.mpk");
pMap->addLayer(dynamicLayer);
JeanneTrieu
Hi Ralf,
Thank you for sending us your feedback. Can you provide more information about the crash? Are you trying to build an application on Linux or Windows?
Is the path provided valid?
thanks,
RalfWiesner
Hi Ralf,
thanks,
I trying to build an application on Windows.
I found the Problem self. The QT Creator had a reference to an incorrect QT versions. I found this Entry in Registry only.
thanks
