ui_rtsample ... not found
2550
04-30-2013 03:11 AM
MassimilianoGeppi
I'm try to compile a simple project using your "qtsampleapplication"
but i'm not found ui_rtsample file, may i know where i can found it?
thank you in advance.
Max
JeanneTrieu
Hi Max,
Thank you for your feedbacks.
Are you trying to compile the "ArcGIS Runtime Qt Sample" that we delivered with the SDK. Unfortunately, we do not provide the UI source however the underline funtionalities are provided.
Thanks.
