ErrorDesc versus Err as exception
1821
06-21-2018 02:14 PM
JoeBorgione
I've been tasked with updating a number of scripts that we run over night as scheduled tasks.  The original scripts use several try: except blocks that look like this:
if arcpy.Exists(gdbPathNameTestBAK):
    try:
        arcpy.Delete_management(gdbPathNameTestBAK)
        print "Success: Deleted BACKUP  " + gdbPathNameTestBAK
    except Exception, ErrorDesc:
        errorFlag = True
        EmailNoticeDeleteBack = "Error: No Delete BACKUP " + gdbPathNameTestBAK
        print str(ErrorDesc) + "Error: No Delete BACKUP " + gdbPathNameTestBAK
# note the except Exception, ErrorDesc:
EmailNoticeExportXML = ""
try:
    arcpy.ExportXMLWorkspaceDocument_management(sdePathName, xmlWorkspacePath, "SCHEMA_ONLY", "BINARY", "NO_METADATA")
    print "Success: Exported XML workspace to " + xmlWorkspacePath
except Exception, Err:
    errorFlag = True
    EmailNoticeExportXML =  "Error: No Export XML workspace to " + xmlWorkspacePath
    print str(Err) + " Error: No Export XML workspace to " + xmlWorkspacePath
#note the except Exception Err:
My question is in regards to the except arguments.  What's the difference between ErrorDesc and Err?  Also, I've changed the the print statements to :
###original --print str(ErrorDesc) + "Error: No Delete BACKUP " + gdbPathNameTestBAK
#mine:
print'{} Error: No Delete BACKUP'.format(gdbPathNameTestBAK)
### original -- print str(Err) + " Error: No Export XML workspace to " + xmlWorkspacePath
#mine:
print '{} Error: No Export XML workspace to'.format(xmlWorkspacePath)‍‍‍‍‍‍‍‍‍‍
After running the print statements I drop the str() method as it does not seem to make a difference.  Thoughts there?
That should just about do it....
DanPatterson_Retired
Joe... I think your ErrDesc is the equivalent to 'e' in this example (and in the python docs)
Difference between except: and except Exception as e: in Python - Stack Overflow
and fancy-schmancy format strings that you are now using, automatically convert anything that has a string representation to a string.  Some objects … like our favorite... None  will show as NoneType
JoeBorgione
Hahaha-  'fancy-schmancy'?!  I learned them from you!
JoeBorgione
As an after thought, these are all in Python 2.x scripts;  I notice when I plug the the try-except blocks into Python 3.x in a Spyder IDE, it will complain if you don't use:
try:
    #some code that may throw an exception
    #exception handling code
#### Note the as e reference####
