What is the python expression for the second, third, fourth etc etc vertex along a line feature? !shape.firstpoint¡ is the first vertex and !shape.lastpoint¡ is the last vertex, but what's the expression for other vertices down the line?
Theres no specific way to do this, this is likely a design decision, as features can have theoretically unlimited vertexes so loading all this info to populate a dictionary etc, could be expensive and have potential to massively slow down cursors.
Check out this article, that tells you the exact same thing I could but using many more words and much more coherently:
Reading geometries—ArcPy Get Started | ArcGIS Desktop
The code at the bottom should allow you to do as you require.
<SPAN class="keyword token">import</SPAN> arcpy infc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Enter for loop for each feature</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>infc<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OID@"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHAPE@"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Print the current multipoint's ID</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Feature {}:"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> partnum <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="comment token"># Step through each part of the feature</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="keyword token">for</SPAN> part <SPAN class="keyword token">in</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Print the part number</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Part {}:"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>partnum<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Step through each vertex in the feature</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="keyword token">for</SPAN> pnt <SPAN class="keyword token">in</SPAN> part<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> pnt<SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># Print x,y coordinates of current point</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{}, {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>pnt<SPAN class="punctuation token">.</SPAN>X<SPAN class="punctuation token">,</SPAN> pnt<SPAN class="punctuation token">.</SPAN>Y<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># If pnt is None, this represents an interior ring</SPAN> <SPAN class="comment token">#</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Interior Ring:"</SPAN><SPAN class="punctuation token">)</SPAN> partnum <SPAN class="operator token">+=</SPAN> 1p <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I agree with Luke that cursors are best when working with more in-depth properties or methods of geometries. If you must work with the Field Calculator, the "Code samples -- geometry" section of Calculate Field examples—Help | ArcGIS Desktop shows how you would retrieve the geometry and then process it in a code block.
