Using cursor to update Hosted Feature Service without login
3717
5
12-20-2021 11:10 AM
Boyang_Wang
Has anyone tried to use ArcPy cursor to update Hosted Feature Service without login? Today I succeeded in using InsertCursor and UpdateCursor on a private hosted feature service using just the URL without logging in to my Enterprise Portal. Does this mean any person can access a private hosted feature service using ArcPy cursor?
Boyang
UPDATE: After testing I confirmed that, without logging to a portal in ArcGIS Pro, I can only edit public features with editing enabled. This conforms to ArcGIS security rules. False alarm.
2 Solutions
jcarlson
If you're using arcpy, you are being authenticated with your organization's portal already in order to check out a license, so I don't think it means anonymous users can edit things.
I could give you a throwaway private feature service URL from a different org if you wanted to test that.
- Josh Carlson
Kendall County GIS
jcarlson
Okay! Here's the URL: https://services6.arcgis.com/U1zX3Wx8hhY7Gb30/arcgis/rest/services/Scratch/FeatureServer/2
There are about 13 random polygons I added. See if anything happens!
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
Boyang_Wang
Hi Josh,
Yes I would like to try that out - whether I can use UpdateCursor to delete all features in one of your throwaway private service via URL.
Boyang
jcarlson
- Josh Carlson
Kendall County GIS
Boyang_Wang
I got an error:
RuntimeError: cannot open 'https://services6.arcgis.com/U1zX3Wx8hhY7Gb30/arcgis/rest/services/Scratch/FeatureServer/2'
You are absolutely right that my Portal login info is stored in arcpy even though I don't have ArcGIS Pro opened (I ran the script in Anaconda) or portal logged in. If I manually log out my account in ArcGIS Pro, I can't access my own private feature service via cursor. Thanks!
DanPatterson
MVP Esteemed Contributor
