Script tp read users last login
1879
11-29-2023 12:00 PM
kapalczynski
I have been using this script for quite some time ... It reads out AGOL account and creates a csv file for those users that have not logged in from 80-90 days.
But recently started getting an error on line 10 below   lastLogintime = user.lastLogin/1000
I am assume this is from the recent AGOL Update?
did it change from    user.lastLogin
ERROR
  File "K:\GIS Share\GIS_AGOLProcessing\UsersAboutToExpire.py", line 84, in <module>
    main()
  File "K:\GIS Share\GIS_AGOLProcessing\UsersAboutToExpire.py", line 48, in main
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 8920, in __getattr__
    "'%s' object has no attribute '%s'" % (type(self).__name__, name)
AttributeError: 'User' object has no attribute 'lastLogin'
CODE
def main():
    #log_obj.info("-- Starting to Process AGOL Users...".format())
    with open(output_csv, 'w', encoding='utf-8') as file:
         csvfile = csv.writer(file, delimiter=',', lineterminator='\n')
         csvfile.writerow(["username", "email", "roleID",
                           "level", "disabled", "role",
                           "licenseType", "lastLogin", "daysSince"])
         counter = 0
         for user in user_list:
            lastLoginTimeConvert = (datetime.utcfromtimestamp(lastLogintime).strftime('%Y-%m-%d %H:%M:%S'))
            format = '%Y-%m-%d %H:%M:%S'
            lastLoginDate = datetime.strptime(lastLoginTimeConvert, format)
            lastLoginDATE = datetime.now() - lastLoginDate
            lastLoginDAYS = lastLoginDATE.days
            varDisabvled = user.disabled
            #if lastLoginDAYS > 80:
            if lastLoginDAYS in range(80,90):
                if varDisabvled == False:
                    try:
                        varusername = user.username
                        varemail = user.email
                        varRoleID = rol_ids[user.roleId]
                        varlevel = user.level
                        vardisabledValue = user.disabled
                        varrole = user.role
                        varlicenceType = user.userLicenseTypeId
                        varLastLogin = lastLoginDate
                        varLastLoginDays = lastLoginDAYS
                        z = (varusername if isinstance(varusername, list) else [varusername]) + [varemail] + [varRoleID] + [varlevel] + [vardisabledValue] +  [varrole] + [varlicenceType] + [varLastLogin] + [varLastLoginDays]
                        output.append(z)
                        counter += 1
                        csvfile.writerow([varusername, varemail, varRoleID,
                                    varlevel, vardisabledValue, varrole,
                                    varlicenceType, varLastLogin, varLastLoginDays
                    except KeyError as e:
                        print(user.username, e)
            print(counter)
Tom_Laue
Make sure your AGOL account you're running the script from is still an AGOL Admin in your org.
If not (like before I was made an Admin in my Org) I could only view my own user details via Python but now I can see others lastLogin.
I just verified this using a test account in AGOL and I get the following error (which I don't get via my Admin login).
Tom_Laue
kapalczynski
Fantastic that was it.... we had reset this user account and for some reason it was removed from admin level.  Pointed to new account and its working...
THANKS @Tom_Laue
kapalczynski
I simplified it working from this example and same error
https://support.esri.com/en-us/knowledge-base/how-to-determine-the-last-login-in-arcgis-enterprise-p...
import arcgis
import time
from arcgis.gis import GIS
#For ArcGIS Online
gis = GIS('https://xxxx.maps.arcgis.com', username="username", password="password")
print("connected")
a_users = gis.users.search(query='', max_users=20)
a_users
for a_user in a_users:
    if a_user. lastLogin != -1:
        last_accessed = time.localtime(a_user. lastLogin/1000)
        print(str(a_user. fullName) + " was last active on: {}/{}/{}\n".format(last_accessed[0], last_accessed[1], last_accessed[2]))
    else:
      print(str(a_user. fullName) + " has never logged in.\n")
ERROR:
connected
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 8917, in __getattr__
return dict.__getitem__(self, name)
KeyError: 'lastLogin'
During handling of the above exception, another exception occurred:
File "K:\GIS Share\GIS_AGOLProcessing\test.py", line 18, in <module>
