Script to update area fields in feature service works in Interpreter but not when triggered by Task Scheduler
3890
16
06-20-2025 01:34 AM
LindsayRaabe_FPCWA
MVP Regular Contributor
I have the below script which does the following:
  1. Logs into ArcGIS Online
  2. Reads a feature service URL from a csv
  3. Uses that feature service URL to save a local copy of the data as a feature class
  4. Recalculates the relevant Area field in the dataset
  5. Disables the editor tracking on the feature service
  6. Uses UpdateCursor to match any updated records to the original in the feature service and updates the area value in the feature service
  7. Renables editor tracking
  8. Repeat for the next feature service in the csv.
This script works when run in the interpretter, and has been running on our server when trigged by Task Scheduler overnight for some weeks. All of a sudden, now it doesn't.
I'm getting told that the feature service URL is not a valid parameter for ExportFeatures, and also not compatible with Update Cursor (according to Copilot).
I managed to find a way around the ExportFeatures issue by using Feature Layer to create a local copy.
What I can't figure out is why this was working with no issues, now isn't despite no software updates being done on the server, or data configuration changes occurring. Has ArcGIS Online restricted the use of the feature service URL as a data source in arcpy?
import arcpy
import time
import os
import csv
import tempfile
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
# Start Timer
startTime = time.time()
try:
    import certifi
    import urllib3
    import ssl
    import warnings
    from urllib3.exceptions import InsecureRequestWarning
    # Overwrite Output
    # Create a default SSL context with certificate verification
    ssl_context = ssl.create_default_context(cafile=certifi.where())
    http = urllib3.PoolManager(ssl_context=ssl_context)
    # Make a request to verify the setup
    response = http.request('GET', 'https://org-wa.maps.arcgis.com')
    print("http response: " + str(response.status))
    # Suppress only the single InsecureRequestWarning from urllib3 if necessary
    warnings.simplefilter('ignore', InsecureRequestWarning)
    # Create GIS object
    print("Connecting to AGOL")
    client_id = '#####'
    client_secret = '#####'
    gis = GIS("https://org-wa.maps.arcgis.com", client_id=client_id, client_secret=client_secret)
    print("Logged in as: " + gis.properties.user.username)
    # Create a temporary directory
    temp_dir = tempfile.mkdtemp()
    # Define the path for the temporary File Geodatabase
    temp_gdb = os.path.join(temp_dir, "tempAreaHa.gdb")
    # Create the File Geodatabase
    arcpy.CreateFileGDB_management(temp_dir, "tempAreaHa.gdb")
    # Set the workspace to the temporary File Geodatabase
    arcpy.env.workspace = temp_gdb
    def remove_last_part(url):
        # Split the URL by '/' and join all parts except the last one
        return '/'.join(url.split('/')[:-1])
    def extract_fc_name(url):
        # Extract the feature class name from the URL and clean it
        path_parts = url.split('/')
        fc_name = path_parts[-3]
        return fc_name
    # Read the CSV file containing feature service URLs
    with open(r'\\gis-prod\orggis\Update\Feature Service Update Scripts\FeatureServiceAreaUpdates.csv', mode='r') as file:
        csv_reader = csv.reader(file)
        next(csv_reader)  # Skip header row if present
        for row in csv_reader:
            featureservice = row[0]
            fc_name = extract_fc_name(featureservice)
            with arcpy.EnvManager(preserveGlobalIds=True):
                temp_Areas = arcpy.conversion.ExportFeatures(
                    in_features=featureservice,
                    out_features=arcpy.env.workspace + "\\" + fc_name,
                    where_clause="",
                    use_field_alias_as_name="NOT_USE_ALIAS",
                    field_mapping=f'AreaHa "Area (ha)" true true false 0 Double 0 0,First,#,{fc_name},AreaHa,-1,-1;GlobalID "GlobalID" false false true 38 GlobalID 0 0,First,#,{fc_name},GlobalID,-1,-1',
                    sort_field=None
            print(f"Features exported for {fc_name}")
            # Determine which area field exists
            fields = [f.name for f in arcpy.ListFields(temp_Areas)]
            area_field = None
            for candidate in ["AreaHa", "Area", "Hectares"]:
                if candidate in fields:
                    area_field = candidate
                    break
            if area_field:
                print(f"Calculating area for field: {area_field}")
                arcpy.management.CalculateGeometryAttributes(
                    in_features=temp_Areas,
                    geometry_property=f"{area_field} AREA",
                    length_unit="",
                    area_unit="HECTARES",
                    coordinate_system='PROJCS["GDA2020_Australian_Albers",GEOGCS["GDA2020",DATUM["GDA2020",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Albers"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",132.0],PARAMETER["Standard_Parallel_1",-18.0],PARAMETER["Standard_Parallel_2",-36.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]',
                    coordinate_format="SAME_AS_INPUT"
                print(f"Areas calculated for {fc_name}")
            else:
                raise ValueError(f"No matching area field found in {fc_name}. Expected one of: 'AreaHa', 'Area', or 'Hectares'.")
            # Remove the last part of the URL
            modified_url = remove_last_part(featureservice)
            # Access the feature layer collection
            flc = FeatureLayerCollection(modified_url, gis)
            # Disable editor tracking
            disable_params = {
                "editorTrackingInfo": {
                    "enableEditorTracking": False
            flc.manager.update_definition(disable_params)
            print(f"Editor tracking disabled for {fc_name}")
            # Create a dictionary from the exported table
            sourceFieldsList = ['GlobalID', area_field]
            valueDict = {r[0]: r[1] for r in arcpy.da.SearchCursor(temp_Areas, sourceFieldsList)}
            # Update the feature service using the dictionary
            updateFieldsList = ['GlobalID', area_field]
            print(f"\nUpdating {area_field} field in {fc_name}...\n")
            with arcpy.da.UpdateCursor(featureservice, updateFieldsList) as updateRows:
                for updateRow in updateRows:
                    keyValue = updateRow[0].upper()
                    if keyValue in valueDict:
                        if valueDict[keyValue] != updateRow[1]:
                            for n in range(1, len(sourceFieldsList)):
                                print(f"Updating {area_field} for {updateRow[0]} from {updateRow[1]} to {valueDict[keyValue]}")
                                updateRow[n] = valueDict[keyValue]
                            updateRows.updateRow(updateRow)
            del valueDict
            print(f"\n{area_field} field updated successfully for {fc_name}")
            # Re-enable editor tracking
            enable_params = {
                    "enableEditorTracking": True,
                    "enableOwnershipAccessControl": True,
                    "allowOthersToUpdate": True,
                    "allowOthersToDelete": True
            flc.manager.update_definition(enable_params)
            print(f"Editor tracking re-enabled for {fc_name}\n")
    endTime = time.time()
    print(f"\nScript completed in {endTime - startTime} seconds.")
except Exception as e:
    if "The Product License has not been initialized" in str(e):
        e = "\n\n" + r"ArcGIS Pro license not available."
    if "cannot open 'https" in str(e):
        e = "\n\n" + r"Login to ArcGIS Online failed - check ArcGIS Pro on the FPC-GIS-01 server is logged in using an Admin account."
    if "Exception: Failed to execute. Parameters are not valid." in str(e):
        e = "\n\n" + r"Either login to ArcGIS Online failed - check ArcGIS Pro on the FPC-GIS-01 server is logged in using an Admin account, or Parameters need fixing if changes have been made in ArcGIS Online to the input layers."
    from email.mime.multipart import MIMEMultipart
    from email.mime.text import MIMEText
    import smtplib, os
    fromaddr = "[email protected]"
    toaddr = "[email protected]"
    msg = MIMEMultipart()
    msg['From'] = fromaddr
    msg['To'] = toaddr
    msg['Subject'] = "Updating AreaHa field process failed (" + os.path.basename(__file__) + ")"
    # Enter email body text below
    body = "There has been an error in the script that checks and updates the AreaHa field in listed feature services. \n\nPlease check the script to troubleshoot any problems. \n\nException: " + str(e) # DON'T include URL's or links to the web in the body of the email or it might get blocked by the scam filters
    msg.attach(MIMEText(body, 'plain'))
    server = smtplib.SMTP('org-wa-gov-au.mail.protection.outlook.com')
    #No login required so this section is commented out
    #server.login("youremailusername", "password")
    server.sendmail(fromaddr, toaddr, str(msg))
    print ("\nScript failed - email notification sent to [email protected]")
    print ("\nException: " + str(e))
Lindsay Raabe
GIS Officer
Forest Products Commission WA
JoshuaBixby
MVP Esteemed Contributor
It might be worthwhile for you to read Scheduling Tasks That Access Portal Data .  That thread has a discussion of different issues and ideas for accessing portal data through scheduled tasks.
LindsayRaabe_FPCWA
Thanks. Will give it a read.
Lindsay Raabe
GIS Officer
HaydenWelch
As far as I know, Cursor objects should be able to handle a FeatureService URL. What could be happening is that you aren't properly authenticated through arcpy or the arcgis.GIS object. Does the user that's logged in to the ArcPro application on the server that runs this have access to those resources?
I would also recommend breaking some of this script out into functions so you can have some more granular error handling. Using environment variables for your globals is a good idea too, that way you can just change the environment if something changes and you don't need to mess with the script.
Logging for services like this is also a must. If you're running it unattended, you want to be able to come back later and check the run logs. With a more granular setup, you could log errors and choose to exit the script or continue (e.g. continue if a single feature service failed and log that it failed, but hard fail if authentication fails or arcpy isn't licensed.)
You can then collect these errors somewhere as the script runs and format them into an email at the end. That way you're allowed to capture multiple possible unrelated failures instead of just the first one that's hit.
I re-wrote this with some of those concepts, can't really test the service functionality as I don't have any AGOL services to connect to. Hopefully you can get something out of it though.
Spoiler
Large Code Block
import os
from pathlib import Path
from requests import get
import logging
from time import perf_counter
from typing import Iterable
# Email Imports
from smtplib import (
    SMTP_SSL,
    SMTPException,
from email.message import EmailMessage
from ssl import create_default_context
# ArcGIS Realted imports
from arcpy import (
    ArealUnit,
    Polygon,
    SpatialReference,
from arcpy.da import (
    UpdateCursor,
    SearchCursor,
    Editor,
from arcgis.gis import (
    GIS,
from arcgis.features import (
    FeatureLayerCollection,
# ------ Script Config BEGIN ------ #
# Create a logger and logfile
LOGGER: logging.Logger = logging.getLogger(__file__)
log_file = Path(__file__).with_suffix('.log')
log_file.touch(exist_ok=True)
logging.basicConfig(
    filename=str(log_file),
    filemode='a',
    format='[%(levelname)s]: %(asctime)s - %(filename)s (%(funcName)s) - %(message)s',
    datefmt='%Y-%m-%d %H:%M:%S',
    level=logging.DEBUG,
# Set globals using Environment Variables or default values
CLIENT_ID: str = os.environ.get('CLIENT_ID', default='*****')
CLIENT_SECRET: str = os.environ.get('CLIENT_SECRET', default='*****')
AGOL_HOST: str = os.environ.get('AGOL_HOST', default='https://org-wa.maps.arcgis.com')
FEATURE_UPDATES = os.environ.get('FEATURE_LIST', default='FeatureServiceAreaUpdates.csv')
SMTP_SERVER: str = os.environ.get('SMTP_SERVER', default='org-wa-gov-au.mail.protection.outlook.com')
SMTP_FROM: str = os.environ.get('SMTP_FROM', '[email protected]')
SMTP_TO: str = os.environ.get('SMTP_TO', '[email protected]')
SMTP_SUBJECT: str = os.environ.get('SMTP_SUBJECT', f"Updating AreaHa field process failed ({os.path.basename(__file__)})")
# Parameters to set before calculation
PRE_RUN_PARAMS = {
# Paramters to set after calculation
POST_RUN_PARAMS = {
# GDA2020 / Australian Albers (EPSG:9473)
GDA2020_AUS_ALBERS = SpatialReference(9473)
# ------ Script Config END ------ #
# Collect exception messages to compile into email
# Format: [{'Readable Name': Exception(), ...}]
# NOTE: Because this is a mutable global, using it as the default argument
# in `build_message` means the message will always contain the errors in this
# list on call
ERRORS: list[dict[str, Exception]] = []
def send_email(from_addr: str, to_addr: str | list[str], subject: str, body: MIMEText, send_success: bool=False) -> None:
    """Send an email using the provided arguments
    Arguments:
        from_addr (str): The message sender
        to_addr (str | list[str]): The message recipient(s)
        subject (str): The message subject line
        body (str): The message body
        send_success (bool): Send a success message?
    # If a success email is not requested and there are no Error logs to send,
    # Do not send the email
    if not send_success and not ERRORS:
        return
    msg = EmailMessage()
    msg['From'] = from_addr
    msg['To'] = to_addr
    msg['Subject'] = subject
    msg.set_content(body)
    # Use SSL context for sending email, if a password is required you will need to
    # set it in the server context
    try:
        with SMTP_SSL(SMTP_SERVER, context=create_default_context()) as server:
            # Consider adding these to Global environment
            #server.login('username', 'password')
            server.sendmail(from_addr, to_addr, str(msg))
            LOGGER.info(f'report sent to {to_addr}')
    except SMTPException as e:
        LOGGER.error(f'Failed to send email!', exc_info=e)
        raise e
def build_message(errors: list[dict[str, Exception]]=ERRORS, success_message:str|None=None) -> MIMEText:
    """Takes the Global ERROR list and formats the body of an email message to send using `send_email`
    If no errors are passeed, a success message is sent
    Arguments:
        errors (list[dict[str, Exception]]|str): List of exceptions to parse and send in email report. (default: `ERRORS`)
        success_message (str|None): If no errors are passed, this string is used as the message body (default: None)
    Returns:
        MIMEText: A MIMEText object with the body of the email message
    messages = []
    if not errors:
        messages.append(success_message)
    else:
        for error in errors: # Error record ({'name': exc, 'name2': exc})
            for error_name, e in error.items():
                messages.append(f'{error_name}:\n\t{e}')
    return MIMEText('\n'.join(messages), 'plain')
def gather_feature_classes(fl: str|Path=FEATURE_UPDATES) -> dict[str, str]:
    """Load all FCs to update from file
    Arguments:
        fl (str|Path): The csv file to load features from
    Returns:
        (dict[str, str]): Mapping of feature name to service url
    try:
        return {
            line.split('/')[-3]: line # Map name to url (fc: https://.../<FeatureService>/ignore1(type)/ignore2(index))
            for line in map(
                lambda l: l.split(',')[0], # Get first column of line
                Path(fl).open().readlines()[1:]  # Get all lines minus headers
    except (IOError, IndexError) as e:
        LOGGER.error(f'Feature updates CSV is malformed or invalid', exc_info=e)
        ERRORS.append({'Read CSV Failure': e})
        raise e
def test_connection(host: str=AGOL_HOST) -> None:
    """Check that a connection can be established to the host
    Arguments:
        host (str): The host to ping (default: `AGOL_HOST`)
    Raises:
        Exception: Log exception, add to ERROR list and re-raise
    try:
        response = get(host)
        if response.status_code == 200:
            LOGGER.info(f'{host} is alive')
            return
        LOGGER.error(f'Unable to communicate with {host}', exc_info=e)
        ERRORS.append({'Host Connection Failure': e})
        raise e
def get_gis(host: str=AGOL_HOST, client_id: str=CLIENT_ID, client_secret: str=CLIENT_SECRET) -> GIS:
    """Log into host using provided creds and return the root GIS object
    Arguments:
        host (str): The host to log into (default: `AGOL_HOST`)
        client_id (str): The client ID to log in with (default: `CLIENT_ID`)
        client_secret (str): The client secret to use (default: `CLIENT_SECRET`)
    Returns:
        GIS: The root GIS object to use for interacting with the host
    Raises:
    try:
        gis = GIS(host, client_id=client_id, client_secret=client_secret)
        LOGGER.info("Logged in as: " + gis.properties.user.username)
        return gis
        LOGGER.error(f'Failed to log into {host} with ***{client_id[-3:]}, ***{client_secret[-3:]}', exc_info=e)
        ERRORS.append({'Host Login Failure': e})
        raise e
def update_definition(url: str, gis: GIS|None=None, params: dict|None=None) -> None:
    """Disable editor tracking for the feature service
    Arguments:
        url (str): The URL of the feature service minus index (`https://.../<Feature>/FeatureServer`)
        gis (GIS|None): The GIS connection to use for updating service (default: `get_gis`)
        params (dict|None): Param mapping passed to  `FeatureLayerConnction.manager.update_definition` (default: None)
    if params is None:
        return
    if gis is None:
        gis = get_gis()
    # If the feature service id is passed in the url, remove it
    if url[-1].isdigit():
        url = url.rsplit('/', 1)[0]
    try:
        flc = FeatureLayerConnection(url, gis)
        flc.manager.update_params(params)
        LOGGER.error(f'Failed to update params for {url}: {params}', exc_info=e)
        ERRORS.append({f'Parameter Update {url} FAILED': e})
def get_area_field(name: str, feature_class: str, valid_fields: Iterable[str]) -> str | None:
    """Validate that an fc has one of the provided fields
    Will handle logging of situations with multiple matches and no matches
    Arguments:
        name (str): The name of the featureclass (for logging)
        feature_class (str): Path to the feature class to check
        valid_fields (Iterable[str]): Iterable of valid fieldnames to check
    Returns:
        str: The first valid field name (multiple matches will trigger logging)
    with SearchCursor(feature_class, ['OID@']) as cur:
        # Find interseciton of valid area fields and feature class fields
        # Log and warn if not
        if not (matches:= set(valid_fields).intersection(set(cur.fields))):
            LOGGER.warning(f'{name} does not have one of {valid_fields}, skipping!')
            ERRORS.append({'Missing Area Field': KeyError(f'{name}: {cur.fields}')})
            return
        # Get first valid field
        match = matches.pop()
        # Warn and log that feature class has multiple valid area fields
        if matches:
            LOGGER.warning(f'{name} has multiple valid area fields {matches} using {match}')
            ERRORS.append({'Multiple Area Fields': KeyError(f'{name} has multiple valid area fields {matches.add(match)}, used {match}')})
    return match
def calculate_area(name: str, url: str, units: ArealUnit='Hectares',
                   *, # KW only below
                   area_fields=('AreaHA', 'Area', 'Hectares')) -> bool:
    """Calculate the area in Hectares of each feature in the service
    Arguments:
        name (str): The name of the feature class
        url (str): The url of the feature service
        units (ArealUnit): The Area unit to calculate (default: Hectares)
        __KW_ONLY__
        area_fields (tuple[str]): List of valid area field names to search for (default: ('AreaHA', 'Area', 'Hectares'))
    Returns:
        bool: True if the calculation succeeds, False if it doesn't
    # Validate field names
    area_field = get_area_field(name, url, area_fields)
    if area_field is None:
        return False # Logging is handled by `get_area_field`
    try:
        with Editor(url):
            with UpdateCursor(url, ['GLOBALID@', 'SHAPE@', area_field]) as cur:
                for gid, shape, area in cur:
                    shape: Polygon = shape
                    proj_shape = shape.projectAs(GDA2020_AUS_ALBERS)
                    if not isinstance(proj_shape, Polygon): continue # For type hinting
                    calc_area = proj_shape.getArea(method='GEODESIC', units=units)
                    if calc_area != area: # Only update rows that require updates
                        cur.updateRow((gid, shape, calc_area))
        return True
        # Don't re-raise failure on area update, log it and carry on
        # This will allow all feature updates to be attempted even if
        # a registerd service is incorrectly configured
        LOGGER.error(f'Failed to update area for {name}: {e}')
        ERRORS.append({f'Area Update Failure {name}': e})
        return False
def main() -> None:
    """Primary flow of the script
    1) Test connection to host
    2) Log into AGOL using creds
    3) Gather all FCs to update from CSV
    4) Iterate FCs and re-calculate Areas in Hectares
    5) Send e-mail with errors, or success
    script_start_time = perf_counter()
    successful_updates = []
    failed_updates = []
    try:
        test_connection()
        gis = get_gis()
        fcs = gather_feature_classes()
        LOGGER.info(f'Updating Areas...')
        for fc_name, fc_url in fcs.items():
            fc_start_time = perf_counter()
            LOGGER.info(f'Updating Area for {fc_name}')
            update_definition(fc_url, gis, PRE_RUN_PARAMS)
            success = calculate_area(fc_name, fc_url)
            update_definition(fc_url, gis, POST_RUN_PARAMS)
            # Log updates
            if success:
                successful_updates.append(fc_name)
                LOGGER.info(f'Successfully updated Area for {fc_name} in {fc_start_time-perf_counter():0.0f} seconds')
            else:
                failed_updates.append(fc_name)
                LOGGER.warning(f'Failed to update {fc_name}')
        # Log script run results
        if successful_updates:
            LOGGER.info(f'Updated Areas for {successful_updates} {script_start_time-perf_counter():0.0f} seconds')
        if failed_updates:
            LOGGER.warning(f'Failed to update {failed_updates}')
        pass
    send_email(
        from_addr=SMTP_FROM,
        to_addr=SMTP_TO,
        subject=SMTP_SUBJECT,
        body=build_message(
            success_message=f'Updated Areas for {successful_updates} {script_start_time-perf_counter():0.0f} seconds'
        send_success=True,
if __name__ == '__main__':
    main()
You should also use `logging` for any automated tasks like this. I have this one set up to log everything to a .log file in the same directory as the script and print out all messages to that log. That way if something goes on, you can tail the logs and see whats failing.
Edit: Of course I find some bugs after I post this.
1) Fixed the calculation operation to apply the new value
2) Fixed the field validation to fail on an empty intersection and check for a non-empty set after the pop
3) Added a main hook
4) Fixed unpacking of the error record list in build_messages
Clubdebambos
Hi @LindsayRaabe_FPCWA,
Out if interest, is there any reason for not using the ArcGIS API for Python to handle it all? with the workflow looking like this...
  3. Get the data as a FeatureSet
  4. Recalculates the relevant Area field in a FeatureSet using Geometry get_area() (There are other Hectare calc options too)
  6. Updates the Area values in the FeatureLayer based on the updated FeatureSet
  7. Re-enables editor tracking
I have done very similar recently and could share the code tomorrow if it is something that would help?
All the best,
Glen
~ learn.finaldraftmapping.com
LindsayRaabe_FPCWA
I would be keen to see your code if you could share please! It's mainly down to my entry/mid level python skills and not know what options there are or how to wield them. Self learning as you go and sticking with what is familiar.
Lindsay Raabe
GIS Officer
Clubdebambos
See below, I have factored in some of your steps. Depending on how of often the schedule runs I would generally use a where clause in the feature layer query() isolating features for that time period only - day, week, etc. Therefore only those where a change occurred (although might not have been geometric) are updated and not the entire dataset each time. Test on a disposable dataset first and see if it matches your expected output.
from arcgis.geometry import Geometry
## Access AGOL whichever way you need to
agol = GIS("home")
## FeatureLayer URLs (you'll read from CSV)
fl_urls = [
    "URL_1",
    "URL_2",
    "URL_3",
## to diable editor tracking
disable_params = {
    "editorTrackingInfo" : {
        "enableEditorTracking" : False
## to enable editor tracking
enable_params = {
## the possible field names to update
area_fld_names = ["AreaHa", "Area", "Hectares"]
## for each Feature Layer url
for fl_url in fl_urls:
    ## create FeatureLayer object
    fl = FeatureLayer(url=fl_url)
    ## get a list of field names from the feature layer
    fld_list = [fld.name for fld in fl.properties.fields]
    ## get which area field is used in the feature layer
    area_fld = [fld for fld in area_fld_names if fld in fld_list]
    ## if an area field found, the list won't be empty
    if area_fld:
        ## get the field name from the list
        aread_fld_name = area_fld[0]
        ## get all features as a feature set
        fs = fl.query(out_fields=[aread_fld_name], return_geometry=True)
        ## for each feature
        for f in fs:
            ## update the area field
            f.attributes[aread_fld_name] = Geometry(f.geometry).get_area(method="PLANAR", units="HECTARES")
        ## get the feature service as an item
        item = agol.content.get(fl.properties.serviceItemId)
        ## create a FLC object
        flc = FeatureLayerCollection.fromitem(item)
        ## turn off editor tracking
        ## update the features
        fl.edit_features(updates=fs)
        ## turn back on editor tracking
Let me know how it goes.
Clubdebambos
Just another thought, if the ExportFeatures is causing you grief with the Feature Layer URL you could replace it with another workflow for FeatureLayer to Feature Class extraction using the ArcGIS API for Python, see below.
## path to where feature classes will be exported
gdb_path = r"path\to\export.gdb"
## you'll read yoiurs from CSV
fl_urls = ["URL_1", "URL_2", "URL_3"]
## Access AGOL
agol = GIS("home")
    ## gte the FL object
    ## make the name consistent with feature class rules
    out_name = fl.properties.name.replace(" ", "_")
    ## get the FeatureSet of the FeatureLayer
    export = fl.query()
    ## save to Feature Class
    export.save(
        save_location = out_gdb,
        out_name = out_name
    ## PERFORM HECTARE CALCULATION
